Author Topic: Cuda Guy Need Help...  (Read 3382 times)
nivvy
« on: October 08, 2008 - 03:24:07 PM »
How are you supposed to put this part on  :lol2:
 :aarg:  :aarg: :aarg: :aarg: :aarg: :aarg:
« Last Edit: October 08, 2008 - 03:41:46 PM by StRoKer »
sleepychallenger
Re: Cuda Guy Need Help...
« Reply #1 on: October 08, 2008 - 04:04:39 PM »
super glue and silly putty  :poopoke:
Offline Oldschool
  • Member Since 9-05-06
« Reply #2 on: October 08, 2008 - 04:10:00 PM »
No easy way...    :grinno:   I am running that plate on the Beast..  The Hemi has head studs under the plate which makes installing those nuts tuff...    :grinyes:  Have to install one head, then the plate (less the center section).  Use plenty of sealer on the ends and at the corners.  Then install the other head.  See?  It's simple really....lol     :working:
Ken  --  In Georgia
Offline moper
« Reply #3 on: October 08, 2008 - 04:58:38 PM »
Step one "remove head"  :bigsmile:
nivvy
« Reply #4 on: October 08, 2008 - 05:03:19 PM »
no heads on the engine.. lol
« Reply #5 on: October 08, 2008 - 05:34:25 PM »
Cuda guy, I'm with Stroker. And I wanna play to :2thumbs:
nivvy
« Reply #6 on: October 08, 2008 - 05:47:13 PM »
lol......... I guess Ill have to bring backup engine then........
 :scared:
« Last Edit: October 08, 2008 - 05:52:42 PM by StRoKer »
Offline mikerallye
« Reply #7 on: October 08, 2008 - 08:28:28 PM »
With all of those dials, gauges, jigs, pointers, a mechanic ought to get paid as much as a Dr!  :lol2:
Offline Challenger6pak
« Reply #8 on: October 08, 2008 - 09:32:52 PM »
I've heard doctors get more because they do it with the motor running.
Offline 73EStroker
« Reply #9 on: October 08, 2008 - 10:44:42 PM »
Actually Stroker, I was wondering the same thing, but after the fact though. I have the same cover and the Indy EZ heads on the low deck block. When I installed it I had the heads on and the water pump stuff off and distributor not installed. So the plate slides in from the front. Thing I did not like though was the fore and aft gaps along beside the heads. Sealing the ends was ok but there seems to me to be something missing there. Sure I filled the gaps with hi-temp sealer and also used the same sealer at the ends as well. So far with cam break in engine runtime and a couple of show off static runs to my chev friends there has been no oil leaks around where my concerns are. No gaskets or anything came with the package from Muscle Motors but I never checked back with Eric @ Muscle to actually see what was needed. Another thing to be careful of is Chryco and I had to drill small partial holes into the bottom of the Holley SD manifold so that it would clear those pesky little allen head bolts. Took about an hour of farting around to get that right. I'll keep watching for more info in this matter.
Barry (Salmon Arm)
nivvy
« Reply #10 on: October 09, 2008 - 10:25:04 AM »
I wont have a problem with the bolts Indy 440-3 intake... I have about 8 hours into porting the intake so far and about 3-4 more to complete it....  :scared:
you should put a dominator on that dominator intake.....  :scared:
Offline ntstlgl1970
  • T a c o c a t
« Reply #11 on: October 09, 2008 - 10:28:04 AM »
ok I'll bite - what is the brass manifold with the plastic tubes going to the intake runners for?
Offline tactransman
« Reply #12 on: October 09, 2008 - 10:31:47 AM »
 :popcorn:
Terry-tactransman
Union, Mo.
« Reply #13 on: October 09, 2008 - 10:33:31 AM »
street car...water iinjection for NOS I believe
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #14 on: October 09, 2008 - 10:39:53 AM »
LOL!!!  Dont worry....  That plate wont save you!
Don
 :aarg:
Member Since January 14, 2002
