Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
one more electrical problem
« previous
next »
Print
Pages: [
1
Author
Topic: one more electrical problem (Read 2392 times)
b5blueaar
Jr. Member
Mad Max Cuda
on:
April 19, 2004 - 08:15:25 PM »
Connected to one tab of the starter relay is a yellow wire from the connector on the firewall. Connected to the other tab is a large brown wire with yellow trace that comes from the nuetral safety switch on the transmission.
When key is turned to start, the relay will not pull in. When I check voltages, both wires have 12 volts.
I can remove the brown wire and connect a ground wire to this tab and everything works fine.
Is the brown wire from nuetral safety switch a ground?
Why does it have 12 volts?
How does the nuetral saftey switch work? It has 3 wires connected to it.
thanks for any tips.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re:one more electrical problem
Reply #1 on:
April 20, 2004 - 01:25:47 AM »
the 2 outer prongs on the Neutral saftety switch operate the reverse lights , power in & power out to the lights , the center prong is the ground for the start relay , you neeed to find out why you have 12v on the center wire
Logged
b5blueaar
Jr. Member
Mad Max Cuda
Reply #2 on:
April 21, 2004 - 01:08:06 PM »
thanks chryco, i'll check it out.
Logged
lemonboy69
Guest
Reply #3 on:
April 22, 2004 - 11:31:22 PM »
My guess would be a short to power somewhere... follow the wire...
that's the best advice I can give...
LB
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
