Author Topic: One last quarter panel install question  (Read 1889 times)
Offline Travis72
« on: October 10, 2008 - 01:17:58 AM »
I'm hoping to finish up the quarter panel install this weekend and have one last fitment question.  The panel between the upper body line and main body line is too flat compared to the arch on the door.  Since I don't have a shrinker, I was thinking about making a small pie cut or two on the panel in the door jamb to see if that allows me to put more curve in to the panel.  Thoughts?  Other sugguestions?   :1zhelp:
Anyone else have this problem?
Thanks,
Travis
72 Cuda
Re: One last quarter panel install question
« Reply #1 on: October 10, 2008 - 01:46:57 AM »
Thanks,
Travis
72 Cuda
Right at the top where the door meets the quarter is too tight on mine. I plan on doing a repair there.
Offline MoparCar
« Reply #2 on: October 10, 2008 - 07:29:55 AM »
Travis,
Any chance sectioning a piece out of your old quarter for the area and transplanting would relieve the "flat spot"? Just a thought but maybe not possible or feasible.
Wes
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
« Reply #3 on: October 14, 2008 - 12:09:44 AM »
Geez  sounds like you got a bad stamp. But it's hard to envision - got pics?
Offline Kapteenikosmos
« Reply #4 on: October 14, 2008 - 12:23:53 AM »
Travis, I did the same on mine. I also had differences in curvature and I did probably 10 cuts or so to get the shape right.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline Travis72
« Reply #5 on: October 14, 2008 - 01:12:32 AM »
After lots and lots of adjusting and trial fitting, I was able to get it to fit the curvature of the door pretty well.  In fact it now amplifies that fact that I had sanded the door flat on the edge right below the main body line (I had a big door crease there).  The very bottom corner area of the door jamb doesn't fit that great and has a small gap that I'll have to bridge with a small piece of sheetmetal, but other than that I'm pretty happy with the overall fit.
Travis
72 Cuda
Offline e-tek
    • E-Tek Resto's
« Reply #6 on: October 14, 2008 - 01:16:04 PM »
Looks great - don't forget to bolt up the rear lower valence before welding!
Offline mopar12372
    • mopartech
« Reply #7 on: February 14, 2009 - 12:31:57 AM »
Travis
72 Cuda
could you possibly post more picture of the install? thanks
RESTO PICTURES
Alaskan_TA
« Reply #8 on: February 14, 2009 - 01:16:11 PM »
Make sure you have the decklid on to check everything before welding as well.
Offline Travis72
« Reply #9 on: February 16, 2009 - 01:08:46 AM »
Mopar12372 you can see some more pictures on page 10 & 11 of my resto thread:
http://www.cuda-challenger.com/cc/index.php?topic=28465.150
I do have a ton of other pictures as well.  If you're looking for something specific send me PM and I can send you pictures that way.
Travis
72 Cuda
Offline mopar12372
    • mopartech
« Reply #10 on: February 19, 2009 - 11:21:59 PM »
Travis
72 Cuda
thankyou :2thumbs:
RESTO PICTURES
