Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Using vacuum gauge for adjusting idle mixture method?
« previous
next »
Print
Pages: [
1
2
Author
Topic: Using vacuum gauge for adjusting idle mixture method? (Read 3360 times)
Katfish
Resident
70 Challenger
on:
October 12, 2008 - 11:32:43 AM »
I picked a vacuum gauge at HF. The plan is to adjust the idle mixture on my Edlebrock carb. It has a stinky rich gas smell.
Is the correct method, adjust until maximum vacuum is achieved, then lean till vacuum drops?
Thx
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Re: Using vacuum gauge for adjusting idle mixture method?
Reply #1 on:
October 12, 2008 - 11:48:09 AM »
You got it.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #2 on:
October 12, 2008 - 11:59:16 AM »
yes, then reset curb idle as it may have increased, do it again, etc. Make sure your timing is set first and foremost.
Tom
Logged
Tom
MEK-Dangerfield
C-C.com Expert
Reply #3 on:
October 12, 2008 - 12:07:46 PM »
...Oh, and do this when your engine is warmed up too.
Logged
Katfish
Resident
70 Challenger
Reply #4 on:
October 12, 2008 - 01:21:47 PM »
Thx for the replies. I've got to do something about this exhaust smell, hopefully this will help.
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #5 on:
October 12, 2008 - 07:49:04 PM »
You may need an assortment of Hg springs for that Edelbrock carb.
Tom
Logged
Tom
the_engineers
Resident
Cheap, fast, reliable...pick 2
Reply #6 on:
October 15, 2008 - 10:50:15 PM »
Can you tell us a little more about the rest of the fuel system? Rich can also be caused by excessive fuel pressure. Do you know what PSI you are running?
Logged
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
1972 Dodge Dart Swinger...keeping the Slant. Rocking the turbos.
Katfish
Resident
70 Challenger
Reply #7 on:
October 16, 2008 - 05:48:39 PM »
On the advice of someone else I did install an adjustable fuel pressure regulator. I have it set for 5.5lbs. Didn't make a bit of difference.
I have now leaned out the idle circuit using the vacuum gauge. It was rich, was able to turn each screw in 1 full turn.
The car still has a stinky rich exhaust smell. Any other ideas? Doesn't seem like either of these changes made much of a difference.
Last Edit: October 16, 2008 - 07:09:26 PM by Katfish
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #8 on:
October 16, 2008 - 06:55:27 PM »
What kind of vacuum i it pulling in gear at idle?
You may need a different set of springs if the vac is lower than the set that comes installed stock.
Tom
Logged
Tom
Katfish
Resident
70 Challenger
Reply #9 on:
October 16, 2008 - 07:08:42 PM »
According to the gauge it started at 18.5, it went as high as 19.5 as I leaned it out. I continued to lean it till it dropped back to 18.5. Can't tell any difference in the way it runs.
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #10 on:
October 16, 2008 - 07:11:41 PM »
Well, the stock springs should be good for that amount of vacuum.lol
How about your initial timing spec?
Tom
Logged
Tom
Katfish
Resident
70 Challenger
Reply #11 on:
October 16, 2008 - 07:48:21 PM »
Not exactly sure, was planning on putting timing tape on and checking it. Last time I checked I think it was 5-7 BTC at idle.
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #12 on:
October 16, 2008 - 08:18:22 PM »
340? maybe a little more intial will clean up your idle stink. Just be sure to check you don't have too much total mechanical advance when all in. You may have to limit the slots in the dizzy if it pings under load.
Tom
My buddies 442's 455 need a bit more initial to clean up his idle seemed to work well, His Wife stopped complaining of Exhaust stink after he drove it anyways.LOL Good enough she lets him take his 2 YO with him now.
Logged
Tom
Katfish
Resident
70 Challenger
Reply #13 on:
October 16, 2008 - 09:03:41 PM »
Yes it's a 340. My problem exactly, wife always complains about the stink on my clothes, and the need to leave the garage open so the fumes don't kill the bird.
Logged
LAA66
Sr. Member
Reply #14 on:
October 16, 2008 - 11:11:50 PM »
What cam are you running? My 340 has the same eye burning fumes possibly from the cam or the Holley 650 DP. Distributor is re curved and timing is at optimum. It runs absolutely great otherwise, very crisp and responsive.
Edit; Thought to add this site for more info.
http://www.secondchancegarage.com/public/186.cfm
Last Edit: October 16, 2008 - 11:46:21 PM by LAA66
Logged
Print
Pages: [
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
