Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Tack...requires shielded wire??
« previous
next »
Print
Pages: [
1
Author
Topic: Tack...requires shielded wire?? (Read 802 times)
DAYLEY/CHALLENGER
Resident
Still My Inspiration..1971, Rockingham, Nc
on:
October 13, 2008 - 07:46:51 PM »
I just can't get the tack to work right. When idling.......ok on the RPM........but on the road I can turnup 8500 and be doing 40 mph, and I am not in First gear either!! Is a shielded wire required as to not pick up any voltage from other sources?
Logged
Dave or David
Chryco Psycho
Administrator
C-C.com Guru
Re: Tack...requires shielded wire??
Reply #1 on:
October 14, 2008 - 02:04:47 AM »
no it doesn`t need shielded wire , the factory tachs are usually screwy & will read way off which is why most people are doing the electronic conversions now , electronic were not very adavnced in 1969
Logged
71 DEPUTY
Full Member
IF YOU CAN'T DODGE IT--RAM IT!
Reply #2 on:
October 14, 2008 - 08:48:55 AM »
mine is the same-electronics inside are old and either need work or get the new replacement ones from RTE
Logged
http://www.cardomain.com/id/71_deputy
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
