Education can be expensive. The answer is lift. Get the valve lift over .500", and the .050" duration above 216 degrees, and the engine will be happier. Domed pistons will give a compression ratio near to 11:1, with no trouble at all. The 383 in my '67 'Cuda is built with an Engle cam of 282/299 gross duration, 235/250 duration at .050" lift, and .516/.555 lift, using 1.5:1 rocker arms. Lobe centers on my grind are 108 degrees, and she is a nasty little girl with this thing. Ross pistons with domes to give a 10.75:1 compression ratio with a .039" gasket, 11:1 with a .020" gasket, and Eagle H-beam rods on a cast crank round out the short block. With 346 heads, stock valve sizes, and Magnum exhaust manifolds, the engine produces 450 BHP on pump-premium gasoline, or 470 BHP on E-85. This is with the MOPAR M-1 single-plane intake, and a mildly-modified 0-3310 Holley carburetor. A dual-plane intake would have been more street-friendly, but I was after more than street manners. An Edelbrock Performer RPM or M-1 dual-plane would be excellent, and work up to 7,000 rpm with a 1/2" spacer under the carb. I recommend a 4-hole spacer in phenolic resin. My heads received no actual porting, although I cleaned up any flashing and casting parting lines, and profiled the valve guide bosses. Maybe this will give you some information to work with. Remember that lift is your friend, and that combustion chamber pressures should be high. Shorter duration vs. lift, with a shorter overlap period, will help you achieve this goal.
