Author Topic: Couple of Challenger questions (trunk, dash pad removal)  (Read 3137 times)
Offline 41husk
« on: October 14, 2008 - 05:31:43 PM »
I would like to have my dash pad redone, rather than go with a cap like I did on the WannaBee, but not sure what that intails on a 70 Challenger convertible.  Do I need to remove the windshield, how many bolts fasten it to the dash frame, basicly how do I do it?  I would also like to see some pics of convertible trunks.  Mostly the jack, space saver and bottle and the overflow from the gas filler tube.  Thanks guys!
1969 Dodge Charger Daytona Clone 440/727
1970 Dodge Challenger Convertible 340/727
1977 Dodge D-700 Car Hauler 361/5spd
2009 Dodge Challenger SRT8 6.1/auto
Offline Lunchbox
Re: Couple of Challenger questions (trunk, dash pad removal)
« Reply #1 on: October 15, 2008 - 02:01:08 AM »
There are 4 bolts on top of the dash on each side of the 2 defroster vents. Also there are two bolts on each side of the dash. Lastly you will need to lower the steering column down and disconnect the various wires and cables and the dash will pull out. It sounds much worse then it really is, just be methodical and check you have everything disconected before you and a buddy start yanking it out.
Lunch
Offline 41husk
« Reply #2 on: October 15, 2008 - 09:11:18 AM »
What is a fair estimate of time it will take?
Offline Lunchbox
« Reply #3 on: October 15, 2008 - 01:27:44 PM »
Maybe 2 hours....It has been 2 years since I took mine out.
Lunch
Offline 41husk
« Reply #4 on: October 15, 2008 - 02:19:19 PM »
Thanks! does anyone with space saver spare have some trunk pics so I can figure out how jack and every thing goes in.
Offline 41husk
« Reply #5 on: October 17, 2008 - 01:13:43 PM »
I could use some help with the trunk! pictures would be great!!!  I have the space saver tire.  My sare hold down has 2 threaded rods a short and a long the long is to the back of the trunk.  Not sure if it is supposed to be there? does the space saver go in back or front of tire up.  does the jack base go on the long or short rod?  I assume the inflater bottle goes on the other?  Do both rods go through lug holes or does one go through the center?  Were does the jack hook go?  Thanks signed Lost!!!
Offline 41husk
« Reply #6 on: October 19, 2008 - 12:59:05 AM »
Wow!, I guess I need to go to dodge charger.com to get questions answered! Thanks for all your help!!
Offline MoparCar
« Reply #7 on: October 19, 2008 - 09:44:24 AM »
Ask for the pictures in the pictures section and you might get a reply. Sorry, I don't have any space saver pictures.
« Reply #8 on: October 19, 2008 - 05:23:09 PM »
 :clueless:   I don't even have a spare in my trunk or a jack or anything. You asked specific questions. Some answered on the dash. I don't think your being ignored or anything.   I got no flippin ideal myself, same as some others.  So try asking for trunk pics next for a heading next time and see how it goes.  Or go to the charger site.  It's all good.
Offline Lunchbox
« Reply #9 on: October 20, 2008 - 01:36:48 AM »
This is all I got and its not of a convert. They are close. Most people don't have the space savers anymore because they are non fuctional plus they are worth about $750 bucks.
Lunch
Offline 41husk
« Reply #10 on: October 20, 2008 - 02:13:58 PM »
Thanks, That pic is so helpfull.  I should make sure in the future I never post anything after a few beers, sorry!  I found that the shorter threaded rod goes with the space saver, but I am still not sure wich of the two possible mounting spots it goes?
Offline Lunchbox
« Reply #11 on: October 21, 2008 - 12:01:09 AM »
If you can get your hands on the jack instructions that would be pasted on the inside of the truck lid it will show you. Mine was painted over so I cant help you and the ones that I have seen on ebay the picture is not clear enough. Maybe someone will come along and post a good pic of their decal which will show you how to mount it.
Lunch
