Author Topic: Looking for taller tires on 14" rallies.  (Read 4857 times)
Offline 41husk
« on: October 14, 2008 - 05:46:10 PM »
I put 215 60 s on my 70 Challenger.  Is there a taller tire that might help fill the wheel well?  It simply doesn't look right.  Do I need to find some 15" rallies to look right?
1969 Dodge Charger Daytona Clone 440/727
1970 Dodge Challenger Convertible 340/727
1977 Dodge D-700 Car Hauler 361/5spd
2009 Dodge Challenger SRT8 6.1/auto
nivvy
Re: Looking for taller tires on 14" rallies.
« Reply #1 on: October 14, 2008 - 06:03:09 PM »
15's ........  :working:
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: October 14, 2008 - 06:24:54 PM »
Here is a picture of my 71 cuda with the stock 14 inch rallye wheels and what would be comparable to the stock tire size (E70-14) 225 70 14 BF Goodrich Radial T/A
1996 Dodge Viper GTS Coupe
« Reply #3 on: October 14, 2008 - 06:28:36 PM »
225 and 70 series on a 14" rim is as tall as you can go. That gives you a 26" wheel. Even if you were to go to 15", you would need a 8" wide wheel to go taller.
Offline hemiken
« Reply #4 on: October 14, 2008 - 06:30:04 PM »
Should be able to get a 215 80 14 for the front and a 235 75 14 for the rear. :2thumbs:
we have these sizes available here in Australia...............
Offline 41husk
« Reply #5 on: October 15, 2008 - 08:08:42 AM »
Thanks guys for the back couldn't I go with a 225 60 14 to give me a little wider back tire ?  I like the look of your cuda! mine looks like I have toy tires and wheels :hyper:
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #6 on: October 15, 2008 - 09:49:21 AM »
Depending on the width rim, I think for a 14x6" rim you MIGHT be able to fit a 235/60-14 tire back there.  Call up a tire shop to see what can be safely mounted back there, I know NTB has a little book they use to see what can fit on what rim.  They told me a 225/70-14 tire will not be safe to put on a 14x5.5" rim with that book.
I have 215/70-14 up front and 225/70-14 in the rears on 6" wide rims.  Makes it look a little fatter inthe rear.
Offline sadil340
« Reply #7 on: October 15, 2008 - 11:15:06 AM »
I have 235 60 x 14 BFG T/A's on my car with Rallye's - let me know if you need a pic
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
Offline 41husk
« Reply #8 on: October 15, 2008 - 02:16:58 PM »
A picture would be great! are 235 higher than 225?  I would think so but some one said above 225s sit 26" high and that was as tall as you could get?
« Reply #9 on: October 15, 2008 - 03:02:26 PM »
235 is higher than a 225, but I mentioned 225 being the tallest you could get in a 70 series tire on a 14" rim. If you go to a 60 series or something else, it's another ball game.
nivvy
« Reply #10 on: October 15, 2008 - 03:34:54 PM »
nice cuda///////
« Reply #11 on: October 15, 2008 - 04:15:59 PM »
I would have to look into this further but I believe the 235/60 tire is shorter as only 60% of the section width is on the sidewall whereas the 225/70 tire has 70% of the section width on the side wall.
So the 60 series will be shorter but wider, 70 series taller and thinner for the #s above.... I think...  :1zhelp:
Offline JayBee
« Reply #12 on: October 15, 2008 - 06:11:09 PM »
FWIW, I used to have Bridgstone 235/60's on the front and 245/60's on the back. They looked nice and wide but bulged out a bit too much on my 14x6's for my liking. Also, they didn't give me the height I wanted, my low lying exhaust would always scrape going up my driveway and sometimes over speed bumps. Now I have BF Goodridge Radial T/A  215/70's all around. I think I would have been better off with 225/70's though.
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #13 on: October 16, 2008 - 12:29:59 AM »
Ok, here's a nice tire size calculator for the fun of it.  :biggrin:
http://www.miata.net/garage/tirecalc.html
Some tire heights....
215/70-14= 25.9"
225/70-14= 26.4"
235/60-14= 25.1"
245/60-14= 25.6"
215/60-14= 24.2"
FYI= I think the 225/70-14 tire is what is typically run on late 60's/early 70's B-bodies.  The 225/70-14 tires/rims I have came from a '70 Road Runner.  The tires that came on my Challenger were 215/70-14 size.
