Author Topic: Crazy horn question  (Read 2799 times)
Offline Ford.P51
Re: Crazy horn question
« Reply #15 on: October 23, 2008 - 09:02:12 AM »
Lots of good info there, thanks for the updates! I haven't had a chance to work on it the last two days, so I don't have any new info.
My plan is to look at the wiring around the ignition switch and make sure there isn't a short, and then start checking all the grounds in the area of the column.
I hate chasing ground problems.  :banghead:
1969 Ford Mustang Mach1
1972 Challenger
« Reply #16 on: October 23, 2008 - 09:11:42 AM »
Just provide a solid gound to your column & see if that fixes it.
Offline Ford.P51
« Reply #17 on: October 27, 2008 - 09:12:31 AM »
And the culprit was ...... bad ignition switch.
The original harness connector between the ignition switch and the fuse box harness was long gone of course, all of the wires were connected with butt connectors. The butt connector for the black wire was pretty crispy, it had obvisouly been pretty hot sometime in the past. The windshield wiper motor only runs for a little while before it overheats and stops, I suspect that it may be the cause of the cooked wire. Anyhow, I think the ignition switch must have gotten a little cooked as well and was shorting out the ground on the column when the key was turned on.
A new ignition switch and a couple hours of wiring cleanup under the dash and everything seems to work.  :bananasmi
One final question - on the column, what is the little black button in front of the hazard switch for? In dismantling the column I broke its mount. :(
1972 Challenger
« Reply #18 on: October 27, 2008 - 10:09:12 AM »
that is the key light
