Author Topic: 70 Cuda Tail lights & side marker lights not working  (Read 11572 times)
Re: 70 Cuda Tail lights & side marker lights not working
« Reply #15 on: October 21, 2008 - 08:49:56 AM »
2 wire switch is for a 70. 71 has a 3 wire plug in
Offline 71340RT
« Reply #16 on: October 21, 2008 - 03:37:36 PM »
Rob I don't see anywhere where the relay is grounded to the housing. Here are a few pictures of the inside.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline ntstlgl1970
  • T a c o c a t
« Reply #17 on: October 21, 2008 - 03:47:38 PM »
Bummer the relay I have doesn't look anything like that one.
« Reply #18 on: October 21, 2008 - 03:54:05 PM »
That's the relay I still have to buy. 70 only
Offline ShelbyDogg
« Reply #19 on: October 21, 2008 - 05:34:26 PM »
Here is the relay as I remember it. I didn't see a ground to the screw and neither did Jeff. It would only work this way if it was either supplying a ground to the lights (if the center pin was hooked to ground)   OR if the switched terminal was getting GROUND from the switch. But then the lights could be left on all of the time, unless a second relay was wired in.
« Last Edit: October 21, 2008 - 05:37:03 PM by shelbydogg »
Offline FY1 RT SE
« Reply #20 on: October 23, 2008 - 06:06:09 AM »
The 70 relay has nothing to do with the on/off function of the fog lamps.  It is only there to turn on the front parking and side marker lights and to trigger the headlights on buzzer if the car is equipped with the A01 package.
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #21 on: October 23, 2008 - 09:35:38 AM »
Shelby is correct- it grounds out in the device it powers.
in 70 the fog lamps are directly powered thru the switch on the dash- it gets it's power thru the 3 prong yellow bullet connector from the acc. power from the ign. switch.
in 71 the changed it to be powered by a relay from the switch.
what is the colors of the wires that feed this relay?????
Offline 71340RT
« Reply #22 on: October 23, 2008 - 12:56:34 PM »
The colors of the wires on the relay plug are pink, green, and yellow.
Offline 71 DEPUTY
    • Cardomain
« Reply #23 on: October 23, 2008 - 02:34:33 PM »
ODD COLORS FOR THAT PLUG
TELL ME WHERE it is located and can you get a pic of the plug?????   I've looked in my manuals and can't find that colors of a plug!!!
John Mac
Offline FY1 RT SE
« Reply #24 on: October 23, 2008 - 02:48:24 PM »
John Mac
Keep looking you will find it, it is in the WD.
Offline FY1 RT SE
« Reply #25 on: October 24, 2008 - 01:18:36 PM »
Come on guys this isn't rocket science.
Offline ShelbyDogg
« Reply #26 on: October 24, 2008 - 05:52:13 PM »
We still need a wiring diagram.  Why did his parking lights come on when he unplugged the relay.
If you know so much, why don't you just tell us how it should be hooked up.
Offline 71340RT
« Reply #27 on: October 25, 2008 - 09:43:45 PM »
Here is the plug and the relay is fastened next to the radio on the vertical flat piece of of metal. The pink wire goes into the pink female plug right next to the relay.
