Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Loose Steering
« previous
next »
Print
Pages: [
1
Author
Topic: Loose Steering (Read 1049 times)
basement
Jr. Member
Loose Steering
on:
October 17, 2008 - 09:49:34 AM »
Have a 74 E-Body with power steering, new front shocks, new front sway bar bushings, new ball joints. The car tracks very good and straight down the highway and around town but it just seems like there is alot of play in the steering wheel, but maybe all Ebodies are like this. I would like to know if there is a way to 'tighten' it up abit? I know by putting a smaller steering wheel on it would give the impression of a more tighter feel but is there something else I can do or should be looking at?
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Re: Loose Steering
Reply #1 on:
October 17, 2008 - 09:57:33 AM »
max positive caster
http://www.cuda-challenger.com/cc/index.php?topic=43922.0
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Super Blue 72
Permanent Resident
"Big 'n Little" Member since 8/9/05
Re: Loose Steering
Reply #2 on:
October 17, 2008 - 10:02:56 AM »
Loose nut behind the wheel?
Sorry, just kidding, couldn't help myself......
Logged
1972 Dodge Challenger Rallye 340, AT, Code TB3=Super Blue, SBD=8/17/1971. Yes, a Rallye without the fender louvers from the factory because of the body side molding option.
Phil in New England-Massachusetts Always thank God for what you have!
73Chally
Resident
Re: Loose Steering
Reply #3 on:
October 17, 2008 - 10:12:43 AM »
Could just be a lot of slop in the box itself, or in the bushings. Is the box original? Pitman arm could be worn. Have someone sit in the car and wiggle the wheel side to side while you watch the steering shaft where it goes into the steering box. If you see the shaft rotating more than a 1/4 -1/2 inch or so either way without trying to turn the wheels, you probably need to rebuild your steering box, or need a new pitman arm.
Logged
71chally416
Resident
Re: Loose Steering
Reply #4 on:
October 17, 2008 - 11:48:10 AM »
You don't get a lot of "feedback" from the steering wheel on old cars with power steering and it feels un-attached to the front end, like an arcade game.
Logged
basement
Jr. Member
Re: Loose Steering
Reply #5 on:
October 18, 2008 - 09:45:37 AM »
Quote from: Super Blue 72 on October 17, 2008 - 10:02:56 AM
OK, you got me.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Loose Steering
Reply #6 on:
October 19, 2008 - 11:35:57 AM »
the wheel alignment on these cars sucks if you set ot factory spec , max the caster , put about 1/2* of negative camber *, set the toe in @ 1/16 " , check the steering box for play , it will steer Far better
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Loose Steering
