Author Topic: Can you identify these brackets?  (Read 3766 times)
Offline jmartin99
« on: October 19, 2008 - 10:48:19 AM »
I am putting together a '72 Challenger Rallye for a friend.  I got the car after it was painted and it came with TONS of stuff in boxes.  I have never worked on a Challenger before so I am looking for help identifying some brackets I found in a box.  There is a possibility they are not for this car or they could even be duplicates because he got a buch of parts from a '74 donor car.
Thanks for looking!
Bracket 1
Bracket 2
Bracket 3  (I think these are supposed to look alike, the one on the left is bent up a bit)
Bracket 4
Bracket 5
Bracket 6
Bracket 7
Bracket 8
Bracket 9
Bracket 10
Jeff ???
Offline dutch
Re: Can you identify these brackets?
« Reply #1 on: October 19, 2008 - 10:55:12 AM »
2 rear bumper bracket
3 footbrake cable (?)
5 rear seat mounting bracket
8 strap down brackets rear framerails
10 front stabilizer to k-member
*** Bart ***
Offline ksierens
    • 70 Challenger Resurrection
« Reply #2 on: October 19, 2008 - 10:55:35 AM »
Bracket #5  Exhaust hanger for duel exhaust
Bracket #7 K-Member to core support
Bracket #8 Rear frame rail "Hold Down" bracket used when shipping.
Kurt - SE Michigan
Offline dutch
« Reply #3 on: October 19, 2008 - 11:02:50 AM »
 :iagree:  on # 5 bracket....right location ,wrong side of the sheetmetal  :misbehaving:
*** Bart ***
Offline heminut
« Reply #4 on: October 19, 2008 - 11:16:49 AM »
#1 is the firewall backing plate for a non-power brake master cylinder.
1970 5.7 Hemi Cuda
Offline sadil340
« Reply #5 on: October 19, 2008 - 11:18:25 AM »
Bracket #6 kinda looks like the rear muffler S-bracket mount but it's different than the one on my '70 - almost looks sideways like it's for an AAR or T/A.
« Last Edit: October 19, 2008 - 11:20:22 AM by sadil340 »
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
« Reply #6 on: October 19, 2008 - 11:39:23 AM »
Thats what I was thinking AAR or T/A.
Some of this stuff cleaned up see what shape they are underneath. Rust away and a blaster then re paint they'll be re usable.
« Reply #7 on: October 19, 2008 - 11:42:58 AM »
4 looks more like the exhaust hanger bracket under the rerar seat , but the seat mount bracket is similar depending on the size
 9 is  inner fender supports for a 71 up B body
« Reply #8 on: October 19, 2008 - 01:12:56 PM »
#9 are the same shape as the fender to radiator support on 72-up Challengers
Offline ksierens
« Reply #9 on: October 19, 2008 - 02:56:33 PM »
I would also guess that both #2 and #4 are bumper brackets.
Kurt - SE Michigan
« Reply #10 on: October 19, 2008 - 03:25:05 PM »
Just so you know, those brackets in pic #8 aren't needed on your car.   :2cents:
Alaskan_TA
« Reply #11 on: October 19, 2008 - 03:32:07 PM »
#6 are not AAR or T/A.  ;)
Offline Slotts
« Reply #12 on: October 19, 2008 - 03:42:03 PM »
#3 Rear bumper guard brackets.
#9 Inner front fender supports.
#10 Front sway bar brackets.
Slotts
Offline 300
  • 69 chevelle,67chevelle , 70 barracuda
« Reply #13 on: October 19, 2008 - 09:01:51 PM »
I have #1 behind my brake booster to firewall.
Offline heminut
« Reply #14 on: October 19, 2008 - 10:16:38 PM »
The ones used on power brakes are attached (spot welded?) to the booster, the ones for manual brakes are separate.
1970 5.7 Hemi Cuda
