Author Topic: Battery Cut off What works best??  (Read 3016 times)
Offline Confederate Cuda
« on: October 19, 2008 - 10:57:08 AM »
Hey guys,
I have a trunk mounted battery and want to install a battery cut off. I will never race this car but would like to have it just to prevent battery drain. Anyone have any suggestions as to the best brand or type? Not sure if it matters but I have a Optima battery (yellow top) 870 amps deep cycle with side mount posts.
Thanks
Mark
Offline GoodysGotaCuda
Re: Battery Cut off What works best??
« Reply #1 on: October 19, 2008 - 11:02:41 AM »
Haven't had a problem with my moroso in 2-3 years or so of use
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #2 on: October 19, 2008 - 11:46:39 AM »
Cole Hersee has them as well , any HD 40amp + swicth should eb fine , I have never had a problem with them
Offline FJ5_440
  • Wisconsin
« Reply #3 on: October 19, 2008 - 01:01:25 PM »
I ran the Moroso for a couple of decades and it never let me down.
** Shane **
« Reply #4 on: October 19, 2008 - 01:22:50 PM »
40a for cranking the car up? Off the top of my head the moroso is in the neighborhood of 175a or so. Quite a jump...
1976 Dodge Warlock
« Reply #5 on: October 19, 2008 - 03:45:32 PM »
Even if you dont race it. It should be mandatory to mount a cut off if the battery is in the trunk
Offline heminut
« Reply #6 on: October 19, 2008 - 10:18:55 PM »
 :iagree: I've had a Cole Hersee switch on mine for over 6 years now. :thumbsup:
1970 5.7 Hemi Cuda
Offline ShelbyDogg
« Reply #7 on: October 20, 2008 - 03:37:14 PM »
If you run a cutoff switch, you have to also install a relay to your alternator field to kill it when the switch is shut off. If not, if the key was on, and you bumped the switch off, the car continues to run off of the alternator without a battery load. The current goes sky high, and you burn out EVERYTHING electronic in the car.  I had to change out every light bulb in the car once.
Offline heminut
« Reply #8 on: October 20, 2008 - 07:33:02 PM »
Not if you run the charge wire from the alternator back directly to the positive terminal of the battery.
1970 5.7 Hemi Cuda
« Reply #9 on: October 20, 2008 - 08:55:04 PM »
I have mine able to shut the drivetrain off from the alternator and battery. No problems, no delay, flip the switch and its OFF. Only thing I do have that stays on is my alarm, and radio (presets/time/etc).
1976 Dodge Warlock
Offline Robco
« Reply #10 on: October 21, 2008 - 11:12:41 AM »
Does anyone have any thoughts about a remote master battery disconnect switch such as the Ron Francis unit? This is where you can run the small switch somewhere that is concealed like under the dash but still get to it if you need to.
« Reply #11 on: October 21, 2008 - 11:22:11 AM »
you can use a relay to cut the power , but it would be en expensive HD relay
« Reply #12 on: October 21, 2008 - 01:21:08 PM »
Running a relay to prevent battery drain wouldn't be very effective, however.
1976 Dodge Warlock
