Arrg
Author Topic: Arrg  (Read 4591 times)
Arrg
« on: October 20, 2008 - 01:51:01 AM »
the flex fan in my Charger decided to move forward a bit or maybe the engine moved on the mounts ... not sure anyway it took out approx 8 tubes in the alum rad tonite  :pullinghair:  :swear:
 I guess i get to buy another new rad + a fan tomorrow  :bricks1:
Offline Carlwalski
Re: Arrg
« Reply #1 on: October 20, 2008 - 01:58:18 AM »
Yikes! Were you nailing it? :burnout: :sly:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Re: Arrg
« Reply #2 on: October 20, 2008 - 03:07:19 AM »
not really
sleepychallenger
Re: Arrg
« Reply #3 on: October 20, 2008 - 06:33:32 AM »
what charger ??? that sucks
Offline Oldschool
  • Member Since 9-05-06
Re: Arrg
« Reply #4 on: October 20, 2008 - 07:52:26 AM »
Bummer.    :swear:   But I guess it could have been worse.....     :grinyes:
Ken  --  In Georgia
Re: Arrg
« Reply #5 on: October 20, 2008 - 08:49:32 AM »
Bummer CP.... had a similar thing happen years ago, all I could figure out was that I must have left something laying under the hood that the fan flung into the radiator.
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Arrg
« Reply #6 on: October 20, 2008 - 09:23:00 AM »
Sorry to hear of your problem, Chryco....  :(  Hoping the title was just you pirate imitation....  :-\
You have a Charger?  We just recently saw your Challenger....maybe Charger pics????  (Fix the radiator problem first!  We can wait for the pics!  :popcorn: )
Offline 1BADFISH™
Re: Arrg
« Reply #7 on: October 20, 2008 - 09:31:17 AM »
You have some luck Neil...   :banghead:   That happened to me one time with my Dodge Demon, I was racing a friend and the belt came off, mangled the fan and that ruined my new rad.    :pullinghair:
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
Re: Arrg
« Reply #8 on: October 20, 2008 - 11:21:36 AM »
Do you know a good mechanic??
  Mike   :misbehaving:
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Arrg
« Reply #9 on: October 20, 2008 - 11:53:22 AM »
  Mike   :misbehaving:
 :roflsmiley: Good one.
That sucks about your radiator.
1996 Dodge Viper GTS Coupe
Offline Supercuda
Re: Arrg
« Reply #10 on: October 20, 2008 - 08:27:07 PM »
I have twice seen a water pump shaft crawl out of its press-fit impeller; once on a Chevy smallblock, and once on a MOPAR smallblock. Check for the danger signs, like misaligned pulleys, or sudden slop in the shaft. I carved a radiator fan shroud once, when I broke a mount. THAT was interesting. I have also seen many clutch fans fail, blowing out the bearings, and consequently running the fan blades into the radiator. Was the rad carved in an even manner, or just a crescent through a few tubes? Sorry it had to happen to you, Chryco.
Re: Arrg
« Reply #11 on: October 21, 2008 - 10:49:40 PM »
Well I found a new rad & will check out the the clutch carefully , I did have a shaft shear off on a 440 one time but it didn`t do that , not sure if the engine torqued & moved on the mounts or if the rad moved or if the fan grabbed some more air & twisted into the rad or if the water pump had an issue although it isn`t loose .... just another day in paradise  :pullinghair:
Re: Arrg
« Reply #12 on: October 21, 2008 - 11:55:15 PM »
Pix
Offline 4Cruizn
  • HEMI FISH
Re: Arrg
« Reply #13 on: October 22, 2008 - 12:14:37 AM »
Dammn . . thats alot of BLUE!!   Is the interior blue also??  Cool car!   :wave:
Re: Arrg
« Reply #14 on: October 22, 2008 - 12:19:57 AM »
Black interior
 Thanks
