Used part question
Author Topic: Used part question  (Read 1766 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Used part question
« on: October 20, 2008 - 09:59:08 AM »
I am starting to put together the list of parts for my 340 build and want to run Harland Sharp roller rockers and a friend of mine reccomended that I consider buying a used set to save a little on the roughly $600 price tag and I was wondering what everyone's take on running used engine parts is?
1996 Dodge Viper GTS Coupe
Offline 1BADFISH™
Re: Used part question
« Reply #1 on: October 20, 2008 - 10:42:38 AM »
I know some people don't like the Harland Sharp roller rockers, but my brother ran a used set in his car for about 2 years and they worked flawlessly. If they're stored properly when not on the engine I don't see the problem. Lots of people buy used adjustable rocker gear for their 340's.    :dunno:
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
Offline 72hemi
« Reply #2 on: October 20, 2008 - 11:03:41 AM »
The big thing I like about them is the needle bearings instead of bushings. The more friction I can eliminate from the better off I'll be.
Offline 1BADFISH™
« Reply #3 on: October 20, 2008 - 11:27:15 AM »
Thats true, but its also the only thing about the harland sharp I heard people not liking, if a rocker blows, you have a bunch of tiny needles through your engine.   :bricks1:
Charlottetown, PE
Offline 72hemi
« Reply #4 on: October 20, 2008 - 11:32:10 AM »
True, but I don't plan on spending a lot of time at high RPM and is one reason I am concerned about buying used.
« Reply #5 on: October 20, 2008 - 12:01:13 PM »
you od not reduce friction with Harland rockers , you still have a the film of oil that creates the resistance but the needle rollers you have far less contact area so it will wear the rocker shafts out
Offline 72hemi
« Reply #6 on: October 20, 2008 - 12:03:28 PM »
But don't the Harland Sharps come with hardened shafts?
« Reply #7 on: October 20, 2008 - 12:08:24 PM »
all shafts are hardened , but when you reduce the load area on the shaft from 1 square inch down to a hair sized contact patch on 4-6 rollers the load on those rollers goes up dramatically
Offline 72hemi
« Reply #8 on: October 20, 2008 - 12:17:05 PM »
That's true. What rockers do you reccomend?
Offline tactransman
« Reply #9 on: October 20, 2008 - 01:53:28 PM »
Terry-tactransman
Union, Mo.
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
« Reply #10 on: October 20, 2008 - 02:33:45 PM »
I also thought that HS use nitration in their shafts because of the needle bearings.
Or chrome moly, heavy walled hard chrome plated shafts.
Offline 72hemi
« Reply #11 on: October 20, 2008 - 02:36:31 PM »
Have you seen this thread?   :cheers:
http://www.cuda-challenger.com/cc/index.php?topic=50078.0
Yeah I have started to go through that thread. Thanks for the reminder though.  :thumbsup:
« Reply #12 on: October 21, 2008 - 02:46:27 AM »
depends on the application , but Mopar or Crane iron rockers are vitually indestructable , I have used some of the Comp Pro Magnum stainless as well
