Author Topic: lower control arm bushings; rubber or poly?  (Read 1277 times)
Offline dutch
« on: October 20, 2008 - 03:19:52 PM »
a while ago I bought this front end kit by energy suspension.  I`m taking apart the lower arms now, so looked what was in the box with new susp. parts and I found the factorystyle rubber bushings and a set of polyurethane bushings.  what would be the better way to go? the car won`t be used very often. just streetuse and an occational sprint. I like stiff suspension, but I hate sqeeks.
thanks,  :thumbsup:
*** Bart ***
Offline ChallengerHK
Re: lower control arm bushings; rubber or poly?
« Reply #1 on: October 20, 2008 - 03:25:55 PM »
Here's a few things to think about:
- The poly bushings I put in are very very stiff
- They backs squeak like you wouldn't believe. I put the lube that came with them on, but there wasn't very much.
- I got some poly bushing lube from Just Suspensions, two pints of the stuff. I slathered it on the front strut rod bushings and they're pretty quiet so far. But, I DID NOT put in poly control arm bushing sin the front (lowers are rubber, uppers I  haven't done yet). My guess is that the strut rod bushings see a lot less stress than control arm bushings.
- Unless you're like me and you like to really hug corners I'd say go with rubber.
- If you use the poly lowers, somebody offers a pivot which is drilled for a zerk fitting so you can add lube without pulling the suspension apart.
- Han Solo, Star Wars
Offline 73EStroker
« Reply #2 on: October 20, 2008 - 10:24:51 PM »
I thought it was the red poly bushings that squeak bad. I used the black ones and used lots of that silicone grease that came with them.
Barry (Salmon Arm)
Offline Aussie Challenger
« Reply #3 on: October 21, 2008 - 06:55:56 AM »
  When I use poly bushes/urethane I cover the bushes with graphite grease, after assembly I clean off excess and no squeaks. I always tighten up bushes after they have been normalised for height, that is at normal ride height.   :2thumbs:
Offline dutch
« Reply #4 on: October 21, 2008 - 05:24:08 PM »
so, how big would the difference in handling be if I use the poly bushings in the lower arms? Will it be noticable when just driving around,or will it take some serious cornering to feel it?     I`ve already redone the upper arms and they got the rubber bushings since there were no others in the kit... also, is there difference in life between the two?
thanks
*** Bart ***
« Reply #5 on: October 21, 2008 - 07:06:39 PM »
It's hard for me to say for sure because I upgraded/replaced so much at once:
Poly shackle and leaf spring hanger bushings
New leaf springs
Boxed lower control arms
Added front sway bar
Heavy duty strut rods with poly bushings
1 inch torsion bars
All of that together made a HUGE difference  :bigsmile:. I'm still planning on tubular uppers with poly bushings, 11/16 tie rods and sleeves and a Firm Feel steering box. I'm going to do something with a rear sway bar but I'm not 100% on what.
Offline dutch
« Reply #6 on: October 22, 2008 - 12:34:48 AM »
ok, thanks
I`ll press out the old stuff later today and see how things come out of the arms.  Blast and powdercoat first, then go from there....
*** Bart ***
« Reply #7 on: October 22, 2008 - 05:01:49 AM »
  As you have rubber in the uppers you probably won't notice a great deal of difference. The uppers aren't that hard to change if you decide to upgrade later.   :2thumbs:
Offline dutch
« Reply #8 on: October 22, 2008 - 06:48:18 PM »
I`ll go poly....   checked on the "new" rubbers, and they already show cracks  :faint:  NOS???  :violin:
thanks for the feedback  :2thumbs:
*** Bart ***
