Author Topic: 4 speed  (Read 689 times)
Offline challengechristian
4 speed
« on: October 20, 2008 - 06:14:31 PM »
just wondering if anybody has a big block 4 speed trans
Offline RaptorF229
  • A work in Progress
Re: 4 speed
« Reply #1 on: October 20, 2008 - 10:39:01 PM »
ihave a granny and big block bell but it needs a different retainer.
Offline Aussie Challenger
Re: 4 speed
« Reply #2 on: October 21, 2008 - 07:30:29 AM »
  They are all the same basically, only the 426 & 440's had an 18 spline instead of the 23 spline, this was used even on the /6. The rear extension housing is the main difference, the E body must have 2 pads on this housing, the rear one is for the  E body. Check www.slantsix.org , it has plenty of info, enough for you to be informed.   :2thumbs:
Offline cuda71sg
Re: 4 speed
« Reply #3 on: October 25, 2008 - 08:18:01 AM »
 :bigsmile:  hi i have one from cuda 71 383  with larger bearing size in front for perfect fit to your bellhousing  and it is a 23 splines tranny if you still need it let me know  www.71sg.com
Re: 4 speed
« Reply #4 on: October 28, 2008 - 01:15:22 PM »
it is a 68 440ci...so that takes the 18 spline?
Re: 4 speed
« Reply #5 on: October 28, 2008 - 01:17:02 PM »
oh ya it is for a e-body too! 1973 challenger
sleepychallenger
Re: 4 speed
« Reply #6 on: October 28, 2008 - 01:51:24 PM »
you can use a 23 spline
