Author Topic: 727 Kickdown for 6-pack?  (Read 4905 times)
Offline 71Cuda4me2
  • Newbie
« on: October 20, 2008 - 08:06:17 PM »
I have 70 Cuda with 440.  Recently added six pack.  My car has the rod from the transmission that I know is supposed to connect somehow.  Can anyone tell me how to connect this or suggest a conversion.  BTW will this burn up my transmission if not connected.  Trans already seems to be getting softer.
Offline hemiken
Re: 727 Kickdown for 6-pack?
« Reply #1 on: October 20, 2008 - 08:21:26 PM »
Yes, this will wreck your trans if it is not connected as you need the kickdown to control line pressure.
Someone will jump on with a picture of how it should be, just be patient and stop driving without it hooked up. :2thumbs:
« Reply #2 on: October 21, 2008 - 02:43:21 AM »
I have seen a company reproducing the whole linkage ...  :banghead:  who was it
Offline 6packCuda
« Reply #3 on: October 21, 2008 - 07:11:53 AM »
You might check with ProMax. They carry a lot of six pack stuff.
Offline tactransman
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #5 on: October 21, 2008 - 11:10:47 AM »
Terry-tactransman
Union, Mo.
« Reply #6 on: October 21, 2008 - 11:17:25 AM »
Tact,
If he doesn't have funds right now, could you explain to him as to how to set the tp lever the old hot rod way by useing the the coat hanger clipped to the hole on the bell housing being adjusted to keep the pressure right without the kick down?  He would have no passing gears, but this kept the pressure right.
I am not good at explaining things, but made them to adjust the shift points.  Still would have to use the shifter to kick down, but it would shift out good when in drive.
Also, for the most part, wouldnt the bottom part of his 4 barrell stuff going down to the trans be about the same coming up to the back of the block and hooking into the swivel on the 6pk bracket. Then the lever slide on the carb would be different and the top swivel?
Offline tactransman
« Reply #7 on: October 21, 2008 - 12:06:14 PM »
Wiring the kick down lever is not a very good deal either,it is OK for like driving the car to get the front end aligned or something like that,but you still should not drive it around that way.
Here is a pic of a set up off the internet if that helps you.
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #8 on: October 21, 2008 - 12:14:18 PM »
Terry-tactransman
Union, Mo.
Offline 71Cuda4me2
  • Newbie
« Reply #9 on: October 21, 2008 - 02:29:41 PM »
Great info thanks.  Picture truly is worth a thousand words.
Offline RaptorF229
  • A work in Progress
« Reply #10 on: October 21, 2008 - 03:27:26 PM »
why not go with the bouchillon cable? It's a lot cheaper
Offline cuda4406
  • andos71RT
« Reply #11 on: October 22, 2008 - 03:33:44 AM »
hi mate
got mine from ebay.com complete set $169.00  seach under mopar kickdown . his user name blinghemi .
cheers darren. :2thumbs:
mopars"R"us
