Author Topic: Drain /Flush Tranny?  (Read 3274 times)
Offline Glennster
« on: October 21, 2008 - 08:16:50 PM »
I've got the old 904 tranny on my 70 Challenger. T
Offline Glennster
Re: Drain /Flush Tranny?
« Reply #1 on: October 21, 2008 - 08:25:24 PM »
I must have hit the wrong key, OOOOOPS...........................
I'm real new to some of this stuff, I'd like to get new oil in my tranny, is there a difference between draining the transmission and flushing the transmission?
I have no idea what to do with this thing, every time I drive past a transmission shop I get a nasty feeling, I've got this thing about tranny shops. For some reason they all seem like scammers to me, I know I'm nuts, but I really want to do this work myself. It seems to me it should be a piece of cake.
  Is there a transmission fluid that is better for the 904?
Once again, THANK YOU for any assistance!!!
« Reply #2 on: October 21, 2008 - 08:50:28 PM »
Please stand by for an important comment from a trans guy that will not harm you
YOU WHO    TACT..............   Hey buddy. \  First time to the dentist routine ok buddy
Glennster. Relax. This is something you will breeze through and come out feeling like a master
Dextron/mercon
Offline Glennster
« Reply #3 on: October 21, 2008 - 09:09:45 PM »
I  just took a few deeeeep breaths, I'm trying to gather , rather than lather myself (there's some that Jesse Jackson stuff for ya) ( crap, I really don't like that stinkin' guy, what a dipstick)
It's SOOOO funny that you mention the dentist, at the ripe age of 50, I'm just now starting to get over my fear of the dentist. I sweat like a pig when I get a simple filling!!!!!!!!!!!!!!!!!
I think I can, I think I can...... Put me in coach ! ! ! ! ! ! !
I'm polishing my wrenches as I wait for my instruction...............................
« Reply #4 on: October 21, 2008 - 09:27:13 PM »
yer so funny :thumbsup:  I want to tell you how simple it is to change the filter and gasket, and to look at the front of the torque converter for a small bolt in the front of it for a drain, but tact will also tell you about maybe doing some simple band adjustments and maybe other stuff.
But go get a filter and gasket for your 904, get the car up on jack stands and make sure you are secure from the car falling on you. Have a big drain pan ready, look at everything around the trans for leaks like selector seal, rear tail shaft seal, tranny lines , dip stick , get a good visual of any place that has been seeping.
I usually start by undoing the 1/2" bolt heads from the back. So when everything is loose the front bolts let the pan tip to the black, allowing to control the trans fluid to some degree .  The filter will have 3 screws holding it on in a SPECIFIC way. It only goes on one way to be correct. Clean the pan, replace the filter, after tact gives you some pointers. It will take close to 5 qts to refill it up if you didnt drain the converter.
When checking the fluid, the car needs to be running and in neutral. Always put the car in drive before reverse. I have left some stuff out but just got you getting a dable of what to expect. It will be easy
I use no silocone and dont over tighten the gasket, it will leak
Offline 422STROKER
  • Member Since 6/3/06
« Reply #5 on: October 21, 2008 - 09:44:35 PM »
Tom
Offline Glennster
« Reply #6 on: October 21, 2008 - 10:01:05 PM »
This is GREAT stuff, when I get this finished, I might open a Tranny shop!!!!!!!!!!!!
I REALLY appreciate the help. This site is filled with great people, everyone wants to help, I love it.
I absolutely love working on my Challenger, I hate to leave her with someone else to do the work. Without you guys, I'm screwed!!! (and BROKE)
THANK YOU, THANK YOU, THANK YOU! ! !
I bought a Honda VTX in 2002 (1800cc V-Twin), the VTX site is like this, great guys helping each other......you could get info on anything.................................
Offline 422STROKER
« Reply #7 on: October 21, 2008 - 10:04:16 PM »
Enjoy!
Tom :2thumbs: :cheers:
Tom
Offline Glennster
« Reply #8 on: October 21, 2008 - 10:29:07 PM »
SWEEEEEEET! ! !
You guys have helped to create the '' Question Monster ''. It's like welfare, once you get a guy on it, he wants it forever...............
My next questions will be about the '' CLANK '' in my 8 1/4'' rear end. We put the old girl up on my buddies lift, he says the slop in the rear end is typical for a 1970 car with 93,00 mile. He says the rear gears are for the Pro's ONLY.............. He's never been on this site...............................
   It looks like Year One sells a rear gear set for about $45, how hard is it for a rookie to properly install rear gears?
Offline tactransman
« Reply #9 on: October 22, 2008 - 08:45:15 AM »
 :wave: It looks like the guys took care of you fine. Hey Glennster,you no newbie no more!  100 posts :clapping:
Terry-tactransman
Union, Mo.
Offline Glennster
« Reply #10 on: October 22, 2008 - 12:38:49 PM »
tactransman,
  Right, 100 posts, most of them QUESTIONS...................
I almost feel guilty getting all this good info for free. Not only that, but it looks like you guys are going to cure of my '' Tranny Guy '' fobia.
Much appreciated Gentlemen!!!!!!!
Offline Glennster
« Reply #11 on: October 22, 2008 - 07:27:21 PM »
Tactransman,
  I read the info on the ''Poor Mans Flush'', this is very cool. But I've got a few questions. This sounds like a three man operation. One to carefully pour fluid into the fill as the car is started. A second to start the car and shut it off at just the right moment.  I picture fluid coming out at warp speed, gushing like crazy. And a third to hang out under the car to see when the fluid comes out clean, so he can give the command to kill the engine.
  Is this right or am I over thinking this. I want to be SURE I get this RIGHT!
Again, THANK YOU! ! !
Offline tactransman
« Reply #12 on: October 23, 2008 - 09:32:21 AM »
No,one man can do it,two guys is easier.
The fluid pumps out the size of the cooler line but not crazy pressure.
If you have to,
put 4 qts in,
start it up,
when it starts running out of fluid,
turn it off,
put four more qts in,
start it up,
when it runs out again,
turn it off,
put the cooler line back on tight,start it up and top it off.
Make sure this is all done in neutral.   :cheers:
Terry-tactransman
Union, Mo.
Offline Glennster
« Reply #13 on: October 23, 2008 - 05:31:58 PM »
I got the gasket and filter last night. They didn't have gallon jugs, so I still need that.
I'll set up a team of three, my Wife will pour fluid (pray for me on that part), my 13 year old son will be the engine on/off guy. I'll be the guy under the car barking instructions.
 Just a few more questions, I '' ASSUME '' the engine/tranny should be hot for this????
 The guys at the parts store sold me some  '  Gasket  Shellac  ', they said that's the stuff to use to hold the gasket to the tranny pan, is this the way to go?
Offline tactransman
« Reply #14 on: October 23, 2008 - 05:47:33 PM »
Just be careful,emergency brake on,block the wheels all that good stuff.
I wouldn't put anything on the gasket.
Trans does not need to be "hot"
Terry-tactransman
Union, Mo.
