Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Timing Tape Install
« previous
next »
Print
Pages: [
1
Author
Topic: Timing Tape Install (Read 1936 times)
Katfish
Resident
70 Challenger
Timing Tape Install
on:
October 22, 2008 - 08:15:50 PM »
Any tips for installing timing tape? I thought it would be easy, just get the car up on jacks and do it from the bottom. K-member totally blocks access, with all the pulleys making it tough from the top.
Any advice?
Logged
femtnmax
Full Member
Re: Timing Tape Install
Reply #1 on:
October 29, 2008 - 10:33:55 PM »
At times I'm sort of a purist. I might pull the pulley off since the access is so bad. Have you checked the timing mark on the pulley to verify top dead center? I would definately do this before applying your tape. I've seen more than one pulley where the outer metal ring had rotated, thus throwing off the timing mark. I then mark the outer and inner metal of the damper so I have a future reference in case of future question. HOpe this helps.
Logged
Phil
BIGSHCLUNK
Sr. Resident
Miss NIKKI - were you this hot at 48?
Reply #2 on:
October 29, 2008 - 11:30:05 PM »
My balancer has 3 grooves in it instead of one. So really make dure to check TDC!
Logged
[o o o o]
OO
OO
[o o o o]
Topcat
C-C.com Expert
Member since 9/16/04
Reply #3 on:
October 29, 2008 - 11:36:46 PM »
I haven't actually done this but I think it might just work.
With the balancer off put on the timing tape. Then spray clear spray laquer from a can on it. I've used these tapes before in the past and they always seem to come off sooner or later. With a clear coat over it, I would think it would be stuck on better so that the edges don't begin to eventually lift off and losing the tape. Think that would work?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
October 30, 2008 - 03:11:01 AM »
or just make a second notch in the damper at 2 3/8 " clockwise from TDC , that is 36* nnow the scale on the timing cover has enough range to adjust a few degees either way from there
Logged
Jim
Jr. Member
Reply #5 on:
October 30, 2008 - 12:57:18 PM »
I gave up on timing tape. Never stays on for long. I invested a few bucks in a dial back timing light.
Logged
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Katfish
Resident
70 Challenger
Reply #6 on:
October 30, 2008 - 04:21:37 PM »
I got it on, at least 1/4 of it. Definitely couldn't get it the entire piece to wrap the all the way around. I then coated the edges several times with some clear nail polish. Hopefully this will keep it on for awhile.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Timing Tape Install
