Thanks, I may try that. Another problem arised today as I was making sure the alternator was charging. I put it in reverse, it made the sound, then I put it in D, it made the sound, same with 1 and 2. This was without moving. I let it warm up in Neutral for a couple minutes, no sound in N or P. To be more accurate with the sound since it happened less than 5 minutes ago, it sounds like a rattling scraping kinda high pitched sound. I am think the clutches are worn out and the flexplate bolts may be backing out?
