Author Topic: trim restoration??  (Read 2964 times)
Re: trim restoration??
« Reply #15 on: October 24, 2008 - 03:36:37 PM »
I have heard that using oven cleaner will remove outer finish and then polish and clearcaot
Oven cleaner worked great on my stainless trim. Just don't use it on aluminum trim. I believe the lower valance molding is aluminum.
Offline larry4406
« Reply #16 on: October 25, 2008 - 07:14:00 AM »
Below is information that I saved from posts along time ago.  I cannot vouch for any of the information/recommendations, etc.  I just saved it for future use by pasting into a WordPerfect document.  I hope it is accurate and useful:
Aluminum Trim Refinishing
Stripping:
You can remove it using Sodium Hydroxide (Lye). It can be found using either Easy-Off oven cleaner or Red Devil Drain Cleaner. I use red devil drain cleaner in a bath (Rubber Maid) tubs, or using 4" PVC. Once in the bath it will be gone in about 10 Minutes. Just make sure you rinse it well when you pull it out of the bath.
The Bath that I have use is as follows
* 1 Gallon of distilled water
* Sodium Hydroxide (lye).......8 oz.
* Sodium Carbonate..............2 oz.
*Trisodium Phosphate..............4 oz.
Sodium Hydroxide ...... Red Devil Drain Cleaner
Sodium Carbonate....... Arm and Hammer Super Washing Soda
Trisodium Phosphate ......Look in the Paint section of a Hardware store under the name of TSP.
Use it warm, the warmer the more aggressive it gets. You may also want to aggitate it. I use a old fishtank bubbler blowing into a piece of 1/2 PVC that I have drilled holes in. Use Gloves since all this is CAUSTIC and will burn your skin.
You can save it and use it again just adding water since the chemicles do not evaperate..
Polishing:
1st step is to use "Tripoli" Compound with a "Sisel Wheel", I use this to remove any sratches. The whole piece will get a quick buff using this.
2nd step is to use "White Rouge" Compound with a "loose section flannel" wheel. This will bring out a near mirror finish.
For tight spots I use a rotory tool with the same compounds.
If you leave it "RAW" you will get away with "Polishing it" with mother's or other metal polishes. I have found "Gords" metal polish to be the fastest.
the PC Glisten will seal in the shine and now you just wash it.
Offline Slotts
« Reply #17 on: October 25, 2008 - 07:56:27 AM »
Take a look into this company, Iverson Automotive:
www.iversonautomotive.com
George Iverson shows every year at the Nats. He does some beautiful restoration work.
Slotts
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
« Reply #18 on: October 28, 2008 - 08:07:54 AM »
the iverson guy seems real reasonable... most reasonable out of everyone i have talked to. thanks guys
Offline 73Chally
« Reply #19 on: October 28, 2008 - 09:00:56 AM »
Do you mind if I ask what he quoted you?  I need to do something with mine, but I'm not sure if I should have it restored or buy new.  You can PM me if you want to keep it private.  Thanks.
David
Offline BIGSHCLUNK
« Reply #20 on: October 28, 2008 - 09:04:26 AM »
Slotts, wow his site is very imformative! I think I know more about stainless now than what I need too!!   :roflsmiley:  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline WVUFELLA
« Reply #21 on: October 28, 2008 - 02:15:29 PM »
He sadi he charges 50 bucks an plus 15%.... for the grill moulding he said around 1.5 hours and the lower valence would be between 2-3.... which is around what i can buy the parts new but( a big but) no one has either of those parts right now ......the grill moulding is on back order thru metro and every other place i have called..... and the lower valence trim is still supposedly being produced ( i have been getting the same answer for the last 2 years) i cant them find anywhere except old junk ones at swap meets.( i have two of them both in not so great shape) i think i am gonna ahave him dothe grill and valence trim........ plus I know they will fit correct there will be no bending and tweaking.. what do you think?? does that sound reasonable??
Offline 73Chally
« Reply #22 on: October 28, 2008 - 02:32:18 PM »
Looks like your thought was a bit incomplete.  Did you mean $50/hr, plus 15% on top of the final charge?  If that's the case, then based on his numbers you're looking at:
Grill: $75
Valance trim: $100-$150
Add 15%: $33.75 (Based on $150 for valance trim)
Total: $258.75
If that's the case then that does seem like a really good deal. Did he give you a time frame?
Offline WVUFELLA
« Reply #23 on: October 28, 2008 - 03:02:14 PM »
yeah the time frame was 8 weeks but depending on the condition and so on and so forth could be shorter.... I think i am gonna gather them up and send them out this week..
Offline Bills70
« Reply #24 on: October 28, 2008 - 04:12:56 PM »
Stripping:
Polishing:
This really does work!!   :2thumbs:
I met a man at a graffitti night and he told me he cleaned all the blue and red color off of those red and blue anodized fittings with oven cleaner then he polished then up and boy do they look real nice!! :drool: so I figure if it works for that it sure should work to clean up our old aluminum pieces!! but he did warn me to make sure to use rubber gloves!!  :bigsmile:
Bill
Offline Lunchbox
« Reply #25 on: October 29, 2008 - 03:44:58 AM »
Keep us informed, I ahve to get mine done too. I have tossed the idea around of getting my repo trim done at the same time as the original to try and match the finish as best as possible. Don't know if it can be done or should be done.
Most of the restored Al and SS trim IU have seen is pretty shinny, the resto stuff is a little duller  :dunno:
Lunch
