Author Topic: Converter failure  (Read 814 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Converter failure
« on: October 23, 2008 - 09:14:44 AM »
How does one know when the converter has had it's best days?  :clueless:
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline tactransman
Re: Converter failure
« Reply #1 on: October 23, 2008 - 09:25:04 AM »
1. A higher stall than normal
2. Dropping the pan and finding metal in it
3. The fluid being black on the dip stick
4. If it is a track car,your E.T. slowing down, your 60 ft. times getting worse and your "Trap R.P.M." at the end of the track being higher than normal.
Terry-tactransman
Union, Mo.
« Reply #2 on: October 23, 2008 - 10:25:19 AM »
OK, so when the trans doesn't react when the car is cold it's the transmission itself?
Offline tactransman
« Reply #3 on: October 23, 2008 - 11:05:43 AM »
It sounds like normal "converter drain down" Start it in neutral and see how it does. (they don't fill the converter in park unless you you have an aftermarket manual spool valve in the valve body,that's why you have to check the fluid level in neutral)
Terry-tactransman
Union, Mo.
« Reply #4 on: October 23, 2008 - 12:15:25 PM »
Thanks for the advice, it's for my -69 300. Propably never rebuild.
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #5 on: October 23, 2008 - 01:06:51 PM »
Did you check fluid level yet?  Colder temps, fluid contracts, goes low, tranny slow to respond - my wife's old car did it all the time (in the winter.)
Jeff
