Author Topic: Dana 60 / Caltracs & MAXIMUM Tire Fitment  (Read 5929 times)
nivvy
Re: Dana 60 / Caltracs & 325-50-15 UPDATED
« Reply #30 on: December 15, 2008 - 03:55:08 PM »
 :cheers:
« Last Edit: December 15, 2008 - 07:09:01 PM by StRoKer »
nivvy
« Reply #31 on: December 15, 2008 - 05:30:18 PM »
Well all the studying / measuring and racking my brain FINALLY paid off for me today as it worked out just as I hoped...
The Tire - Mickey Thompson 29" tall and the tire comes in at a enormous 13 5/8 Section width and 11+ tread width..,
its 3/8ths from the spring now and the general rule of thumb is about 1/2 on either side...
A real thin wheel spacer would move it off the spring some and still have plenty of clearance to the outer wheelwell lip which is about 1+ now...
« Last Edit: December 15, 2008 - 07:10:41 PM by StRoKer »
Re: Dana 60 / Caltracs & MAXIMUM Tire Fitment
« Reply #32 on: December 15, 2008 - 08:11:08 PM »
MAN that is close!!    :clapping:
nivvy
« Reply #33 on: December 15, 2008 - 08:15:14 PM »
naaaaaa I got over an 1+ to the lip to move off the spring a hare if needed   :naughty:
Offline vinb
« Reply #34 on: December 15, 2008 - 09:29:55 PM »
StRoKer,
My buddies B/SA Stocker Challenger uses 9"x30" which are 94" round with Mono Cal-Trac's no clearance issues..
1.38 60'.....
nivvy
« Reply #35 on: December 16, 2008 - 04:42:48 AM »
StRoKer,
1.38 60'.....
how close is his 30" tire to the front of the 1/4 panel due to growth ....
Offline Roppa440
« Reply #36 on: December 16, 2008 - 09:10:54 AM »
I asked this in another thread but how wide are those rear wheels and what is the backspace on them?
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
nivvy
« Reply #37 on: December 16, 2008 - 04:20:40 PM »
15*10 with 5" of backspacing....
Offline vinb
« Reply #38 on: December 16, 2008 - 07:46:03 PM »
StRoKer,
I'm not sure on his car,  but on my Cuda Stocker I had to trim the wheel opening a bit. He probably did the same.
I ask him tomorrow when I see him. I know he uses Hooiser & Goodyear radials 92's & 94's and they don't really grow much at all. I do know the M/T's & Firestones do grow alot..
nivvy
« Reply #39 on: December 17, 2008 - 02:17:38 PM »
Im running tubes also so growth wont be as much either....... growth is even less with the et street radials....
30"  295/65/15 Et Street Radial and they dont rub and he does 140mph on motor...
Offline 74 340 4speed
« Reply #40 on: December 17, 2008 - 11:43:36 PM »
Looks good man. How is your drivability going to be on the street with a spool?  I thought that was primarily for track use?
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
nivvy
« Reply #41 on: December 20, 2008 - 11:05:15 AM »
Spools are fine on the street as long as you dont go barreling around turns.. the guy with the blue hemicuda above has been using a spool for years with no issues.... his car is 3800lbs and runs mid 9's on motor ....  :working:
« Reply #42 on: December 20, 2008 - 05:59:02 PM »
Same here, spool on my cuda for years on the street , but 9.70 street car :2thumbs:
