It will work with the correct components , the 11" system will bolt in no issue , the belhousing has to have the same size hole as the front brg retainer on the tranny or you may need a adapter ring if you have the smaller 4.35" retainer on the tranny & a 4.8 " hole in the housing , the Belcrank will bolt in , the clutch fork is available or will work depending what you have , you will need the larger 11" clutch system , the 10.95 will not work , you also need to match the spline either 18 or 23 spline for the clutch disc , same with the flywheel , the 143 tooth flywheel is the one you need
