Author Topic: 8 3/4" axle shaft dimensions  (Read 3913 times)
Offline Automotive Engineer
« on: October 24, 2008 - 06:21:25 PM »
Hi
I would need the 8 3/4" axle shaft dimensions to make an order for aftermarket axles.
I was asking a set from Moser, but they need the exact dimensions even the rear axle is stock. I was a little bit surpriced that they did not had any documentation of this.
Check the order form and needed dimensions, link attached
http://www.moserengineering.com/Images/Ordering/order-form.pdf
All help is appreciated!
Re: 8 3/4" axle shaft dimensions
« Reply #1 on: October 24, 2008 - 07:31:10 PM »
« Reply #2 on: October 24, 2008 - 07:42:42 PM »
http://www.mymopar.com/Mopar8_75RearEndGuide.htm
http://www.mymopar.com/axledims.htm
 these should have what you need
Thanks for the links, but sorry, I didn't find the axle shaft dimensions that are needed for making an order.
Probably I should visit a optician to have new spectacles
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #3 on: October 24, 2008 - 08:10:35 PM »
Try this
For more detailed info go to: www.moparts.com and click on the tech archives. There's a ton of info on the Mopar rear end. You'll have to sift through it to find exactly what you are looking for. Hope this helps!! :bigsmile:
                                                   Matt B.
Moparts Tech Archive
Rear Axle
Axle lengths 8 3/4
I'll post the whole 8 3/4" thing again for those who didn't get it the first time:
Mopar 8 3/4" Rear End Dimensions
8 3/4" axle shaft lengths measured from the tip of the splined end
to the outside of the flange:
A BODY
'66-'72= 27 11/16"
B BODY
'65-'67= 28 7/8"
'68-'70= 29 3/16"
'71-'74= 30 5/8"
'71-'73 wagon= 31 21/64"
C BODY
'65-'69= 30"
'70-'71= 30 5/8" (Chrysler & Fury)
'70-'73= 31 21/64" (and '69 wagon)
IMPERIAL (Large Bolt Pattern)
'65-'66= 30 1/8"
'67-'69= 30 5/16"
'70-'71= 29"
'72-'73= 31 7/16"
E BODY
'70-'74= 29 31/32"
A100
'65-'70= 30"
D100
'65-'71= 31 1/8"
'72-'74= 31 21/64
Housing widths, flange to flange
A BODY
'66-'72= 52 5/8"
B BODY
'62-'63= 53 1/4" (And '64 Max Wedge)
'64 = 55 5/8" (Exc. Max Wedge)
'65-'67= 54 1/4"
'68-'70= 54 15/16"
'71-'74= 57 7/8"
'71-'73 wagon= 59 7/16"
C BODY
'65-'69= 56 3/4"
'70-'71= 57 7/8" (Chrysler & Fury)
'70-'74= 59 7/16" (and '69 wagon)
IMPERIAL
'65-'66= 57"
'67-'69= 57 3/8"
'70-'71= 54 3/4"
'72-'73= 59 5/8"
E BODY
'70-'74= 56 31/64"
A100
'65-'70= 56 3/4"
D100
'65-'71= 58 5/16"
'72-'74= 59 7/16"
Rear end widths, drum-to-drum:
A BODY
'66-'72= 57 1/8"
B BODY
'62-'63= 58 1/2" (And '64 Max Wedge)
'64 = 60 7/8" (Exc.Max Wedge)
'65-'67= 59 1/2"
'68-'70= 60 1/8"
'71-'74= 63"
'71-'73 wagon= 64 3/8"
C BODY
'65-'69= 61.75"
'70-'71= 63.0" (Chrysler & Fury)
'70-'73= 64 3/8" (and '69 wagon)
IMPERIAL
'65-'66= 61 15/16"
'67-'69= 62 5/16"
'70-'71= 59 3/4"
'72-'73= 64 9/16"
E BODY
'70-'74= 61 5/8"
A100
'65-'70= 61 3/4"
D100
'65-'71= 63 15/16"
'72-'74= 64 3/8"
Spring perch widths (center-to-center)
A BODY
'66-73= 43"
B BODY
'62-'70= 44"
'71-'74= 47.3"
C BODY
'65-'73= 46"
E BODY
'70-'74= 46"
Tech Index
« Last Edit: October 24, 2008 - 08:16:03 PM by moparmaniac59 »
Matt
« Reply #4 on: October 24, 2008 - 08:23:54 PM »
Thanks moparmaniac59, your link helped little, but still I would need the dimensions K, B, H and A as they are asked on the Moser's Order Form., take a look from the link
