Author Topic: Can 72+ Cuda round tailights be separated?  (Read 2161 times)
Offline GoodysGotaCuda
« on: October 25, 2008 - 09:54:41 PM »
Looking for any methods or suggestions on separating my round tailights. To clean inside there, and also maybe attempt to retrofit some LEDs into...
Like these
 :clueless:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline bb71challenger
Re: Can 72+ Cuda round tailights be separated?
« Reply #1 on: October 26, 2008 - 12:56:59 AM »
From the ones I have I dont think they were made to come apart. I bet you could do it and easily plastic weld them back together when you got your work done. It would probably help to use some spare ones so you would not be rushed on time to do the work.
*Brett*
Offline aarcuda33
« Reply #2 on: October 26, 2008 - 01:07:54 AM »
Goody
 I have never tried to take them apart but I have seen the lenses only for sale NOS so I would say they were made to come apart .
Good luck
 aarcuda33
« Reply #3 on: October 26, 2008 - 02:58:01 AM »
I got curious enough to look at the ones I have. They have tabs on them and slots in the black plastic housing so they will come apart. I think you will have to be careful not to break the tabs, it looks like the black plastic housing is the place to pry enough space to release the lens. Good luck.
Brett
*Brett*
Offline Aracer
« Reply #4 on: October 27, 2008 - 12:36:41 AM »
They have LED white composite replacement bulbs for older cars @ AutoZ for $16/pair. 13.8 V rated. Then all you have to do is change the bulb from inside the trunk.
Offline miketyler
    • www.miketyler.net
« Reply #5 on: October 27, 2008 - 06:58:47 AM »
am interested in doing something like this also. I like the way the G35 LED taillights look and would like to see something like them on the Cuda
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Aracer
« Reply #6 on: November 09, 2008 - 12:26:24 PM »
Why go brighter? It only makes you stand out and it's easier to be followed by the speed cops. I used to go duller with 1057's instead of the 1157 tail lights. But, I can see it would be a nice art project to upgrade to those skyrocket type displays. Use a very fine hack saw to separate the red lens from the black plastic and re-glue with superglue + Tak Pack (3M) hardener for instant bonding.
« Reply #7 on: November 09, 2008 - 12:29:07 PM »
Why go brighter? Because other driver's are stupid and hardly pay attention. I hardly would think that cops would be attracted to brighter tails when I'm driving a bright yellow, loud muscle car to begin with...
Also a little heat from a heat gun and i am able to separate them and reattach them with no problem.
1976 Dodge Warlock
nivvy
« Reply #8 on: November 09, 2008 - 12:54:37 PM »
not bright at all....... there led stuff is cheap/ junk... I tried there stuff  :working:
Offline Aracer
« Reply #9 on: November 13, 2008 - 12:35:34 AM »
dull lights fade quicker on the highway, and let you avoid being targeted. go ahead and run neon while your at it.   :dupe: or add a rear window brake  :scared: display :roflsmiley:
Offline cudax34me
« Reply #10 on: November 17, 2008 - 10:07:04 PM »
depending on the cop.....if you drive a muscle car you are already standing out and will be pulled over.been there done that.
that said i don't know about other states but in mississippi if you run from the cops it's a felony.
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #11 on: November 18, 2008 - 02:44:30 AM »
 :thinkerg:
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline Aracer
« Reply #12 on: November 19, 2008 - 03:59:45 PM »
You aroused my curiosity so I tried the red LED replacements. I like them, because they do not glow on and off, they flash with dark moment between. They also do not glow to the side as much, but directly behind they pop out when the brakes are on. Plus no extra work for the experiment and they use less amps to run. (Never said I running from the cops, just losing the pack animals.)  :aarg:
Offline cudax34me
« Reply #13 on: November 25, 2008 - 08:10:46 PM »
Like these
 :clueless:
i just noticed a add in the dec/jan mopar enthusiast for ClassicLEDs.they show pics of '72-'74 cuda tail lights,'71-'72 charger se and '68 charger.the website http://www.northwestmustang.com/ has the '68 charger,'70 cuda and '69 roadrunner lights. looks like someone was reading your mind.
Offline 4Cruizn
  • HEMI FISH
« Reply #14 on: November 25, 2008 - 11:20:01 PM »
 :useless:
