Author Topic: automatic brake pedal spring  (Read 2530 times)
Offline noschevys
« on: October 26, 2008 - 07:35:59 PM »
Does anyone have a pic or know how the spring that hooks to the brake pedal linkage and pedal frame assembly in the interior of the car gets hooked up?
Offline heminut
Re: automatic brake pedal spring
« Reply #1 on: October 26, 2008 - 07:40:00 PM »
I don't have a spring on my brake pedal! :clueless:
1970 5.7 Hemi Cuda
Offline noschevys
« Reply #2 on: October 26, 2008 - 07:46:05 PM »
The spring hooks to the pin that hooks to the pb booster and is connected to the brake pedal linkage.  Not sure how the top end of the spring hooks to the pedal support which is bolted to the dash and thru the firewall.
« Reply #3 on: October 26, 2008 - 10:07:24 PM »
Can you give us a picture of what your talking about?
Offline G_Man440
« Reply #4 on: October 27, 2008 - 03:01:11 AM »
I had trouble remembering where that spring went myself. I looked at multiple cars that did not have it, and then I finally remembered how it goes. I can send you a picture of how it mounts if you need it but it will take me a few days. I just put the car away for the week and don't have easy access to the driver side. It may be tough to get the picture from the pass side but I'll give it a try.
70 Challenger R/T, 440, 727, AC
Offline noschevys
« Reply #5 on: October 27, 2008 - 08:49:44 AM »
Thanks, I would really appreciate it.   :cooldancing:
« Reply #6 on: October 27, 2008 - 08:57:49 AM »
As many of these that I have taken apart, I can't picture a spring under the dash inside the car :clueless:
Brake pedal, brake pedal rod swivel, brake pedal rod is on the back uof the booster on the firewall. That has a cone spring on it with rubber seal over it. Is that the spring your talking about?
Offline noschevys
« Reply #7 on: October 27, 2008 - 09:25:13 AM »
the brake pedal booster rod is attached by a pin to the brake pedal linkage.  The pin has a grove in it that a spring hooks to then hooks up to the pedal support frame.
« Last Edit: October 27, 2008 - 09:32:24 AM by noschevys »
Offline hemiken
« Reply #8 on: October 27, 2008 - 09:40:44 AM »
This spring is only found on disc brake boosted cars with this special linkage on them :2thumbs:
Offline shawge
  • Zoiks!!
« Reply #9 on: October 27, 2008 - 01:23:58 PM »
My 70 Challenger w/ power drums on all four corners had this spring  :dunno:
- Jerry
Offline hemiken
« Reply #10 on: October 27, 2008 - 08:32:48 PM »
I meant boosted cars with the offset linkage :banghead:
« Reply #11 on: October 28, 2008 - 07:31:00 PM »
I got a box full of booster parts off my 74 challenger. Did you find the spring or do you need me to go digging in the box?
Offline noschevys
« Reply #12 on: October 28, 2008 - 08:20:53 PM »
I have the spring, was just wondering how the top of the spring attached.
Offline G_Man440
« Reply #13 on: October 30, 2008 - 02:08:21 AM »
I have the pictures you need for the spring attachment. I can Email them to you if you like. Your address is hidden. Right now I cannot get them resized to post. I am computer illiterate and have zero patience for stuff that does not work easy. I have already screwed around for an hour and am giving up.
I apologize to everyone for my bad attitude. i'll try another day when I am less frustrated and have more time.
I left my rant for everyones amusement. I think I figured it out.
Offline noschevys
« Reply #14 on: October 30, 2008 - 09:20:33 AM »
Perfect.  Thanks for all your trouble.
