Author Topic: 8 1/4 Rear End - Drain, Clean and Refill?  (Read 1043 times)
Offline Glennster
« on: October 26, 2008 - 08:02:56 PM »
I 'd like to get some fresh oil in my old 8 1/4 rear end. My plan was to pull the rear plate, blast the gears and everything in there with my favorite cleaner (starter fluid) to get rid of all the sludge that's in there.
Then, fill her up with the proper gear oil. Once again I come to the experts for some help.
1. Is this a sound plan of attack? If not, please tell me ..............
2 What's the best oil to use in there? Synthetic?
Thanks!
nivvy
Re: 8 1/4 Rear End - Drain, Clean and Refill?
« Reply #1 on: October 26, 2008 - 08:12:42 PM »
Dr Diff recommends Supertech 85w140...... walmart stocks it also.........  :working:
thats what im putting in my dana 60  :bigsmile:
« Reply #2 on: October 26, 2008 - 09:36:42 PM »
sounds ok , either 80-90 gear oil or 75-90 synthetic
Offline Glennster
« Reply #3 on: October 26, 2008 - 09:56:01 PM »
I hear that synthetic tends to leak where dino oil will not, could that be an issue with my old rear end?
I run synthetic in my 2002 Honda 1800cc V-Twin motor and rear gears, this bike shifted with a big clunk UNTIL, I went synthetic..................
Offline 71chally416
    • The Streetwalker
« Reply #4 on: October 26, 2008 - 09:59:09 PM »
Only used the syn lube once in 35 years, and the rear broke behind a weak motor. Never again.  :grinno:
Offline Glennster
« Reply #5 on: October 26, 2008 - 10:12:13 PM »
How could the Synthetic lube have caused that?
« Reply #6 on: October 26, 2008 - 10:14:01 PM »
I have had no issues with synthetic , but I don`t put a lot of miles on my cars either
Offline 71chally416
    • The Streetwalker
« Reply #7 on: October 26, 2008 - 10:23:22 PM »
Don't know. The rear somehow survived since 1969 with regular gear lube. It was a 3.91 OEM out of a Superbee. Started making a clicking noise with the old 360 my car came with and when I pulled it out....
Offline 71chally416
    • The Streetwalker
« Reply #8 on: October 26, 2008 - 10:25:20 PM »
The lube probably had nothing to do with the failure, but I've never broke a rear gear with such a weak motor. I'm not using it anymore.  :grinno:
