Author Topic: Windsheild trim  (Read 1676 times)
Offline kmyles
Windsheild trim
« on: October 27, 2008 - 11:44:50 AM »
Does anyone know how to attach the windshield trim if the nobs that hold the trim fastners are gone? During the rebuild the nobs were cut off or rotted off from rust!! Any ideas??
 :working:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline farmertan
Re: Windsheild trim
« Reply #1 on: October 27, 2008 - 11:53:04 AM »
i just removed my trim and i wouldnt trust the old retainer clips i would buy all new clips.
73 340 4sp 2nd owner since 85    brett
Offline kmyles
Re: Windsheild trim
« Reply #2 on: October 27, 2008 - 12:02:44 PM »
It's not the retainer clips, it's what holds the retainer clips that is rusted off :scared:
_________
Kevin
Re: Windsheild trim
« Reply #3 on: October 27, 2008 - 12:33:28 PM »
70 models had screws in stead of knobs. The clips screwed down then the trim installed. Window should be out to do it right tho
Offline kmyles
Re: Windsheild trim
« Reply #4 on: October 27, 2008 - 01:21:29 PM »
Could I do it this way on my 71 :dunno:
Has anybody ever done it this way. :pullinghair:
 :working:
_________
Kevin
Offline ntstlgl1970
  • T a c o c a t
Re: Windsheild trim
« Reply #5 on: October 27, 2008 - 02:14:23 PM »
You can do it with the screw in clips or find someone with a stud gun (for pulling dents). They make new window trim studs that are welded on with the stud gun.
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
Re: Windsheild trim
« Reply #6 on: October 27, 2008 - 02:22:12 PM »
WS shops often repalce all those rusted studs with screws. The studs didn't last long in most cars.
Offline 73EStroker
Re: Windsheild trim
« Reply #7 on: October 29, 2008 - 08:42:56 PM »
Or use pop rivets. What ever you use (screw or pop rivet) place a little urethane sealer around the hole first to prevent moisture seepage in past the screw or rivet. small thing but in 5 years time you don't want to be showing off the car to someone and they sa "isn't that some rust coming around your windshield?"   :swear:
Barry (Salmon Arm)
Re: Windsheild trim
« Reply #8 on: October 29, 2008 - 09:38:11 PM »
I tried that but the problem was the coopper grounding nozzle won't let you get a flat contact in the beveled area where the stud goes. The ground nozzle it's bigger than the ridge area the stud would get weleded to.
Offline MoparCar
Re: Windsheild trim
« Reply #9 on: October 30, 2008 - 07:39:36 AM »
A couple years back I saw a guy on Moparts.Com modify his stud welder nozzle by basically grinding down the tip to fit. It appeared to work great. It looked like two flat spots, one on each side.
