Author Topic: 70-71 auto floor hump  (Read 1344 times)
Offline skinny1
  • I love YaBB 1G - SP1!
« on: May 19, 2002 - 07:31:24 PM »
I have a center hump or tunnel for 70- 71 challenger, includes brackets for slapstick console.probly fit 72 74. I also have rad. support and front rail sections for the same .have a pair of really good lock pillars also.
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
Offline mspcuda
engines and parts
« Reply #1 on: April 18, 2007 - 09:22:43 AM »
I have a 1976 440 long block. It has 452 heads, mopar purple cam/lifters (will post specs soon), oil pump, driver inlet water pump housing, cast crank. Ran well when I took it out. $400 obo plus shipping
Have 383 block, mains. bored .30 over. needs to be honed, rodded out but line bore seemed good when crank was removed. dated '68, maltese cross on pad. $300 obo plus shipping. Will give you date code upon request.
383 forged crank, needs to be turned.
Set of 383 .30 over Jahns forged alum. pistons. Dome top, good shape with floating wrist pins attaching standard rods. The above crank is balanced for this rotating assembly. $200 obo
440 Edelbrock Performer RPM intake, Ran about 20 minutes, Hemi orange. $160 firm plus shipping
383 Torker intake, good shape, needs cleaning, not painted. $125 plus shipping
Stock 440 intake mani. Dirty. $90 plus shipping. will get codes upon request.
383 Mopar solid purple cam and lifters. Might as well be new. .557 lift, 296 adv duration, 252 duration at .050, lobe centers 110 deg, overlap 76 deg. $180 plus shipping.
Milodon Dry sump remote oiling system. 3 filters, all connections included. No pan. More info soon. $225 plus shipping.
Mickey Thompson Aluminum Valve covers. Need polishing but in good shape. $80 plus shipping.
383 Solid damper, 1 piece NHRA, forged crank, internally balanced, $80.
Cloyes Double Roller gears and chain for 3 bolt cam. came off 383. Looks good. $50.
Contact Matt at: mspcuda@gmail.com
Thanks Cuda-Challenger!
 :cheers:
Push a Chevy, Drive a Ford...just get out of my way.......MOPAR OR NO CAR!
