Author Topic: How much oil in 8 1/4'' Rear End"  (Read 691 times)
Offline Glennster
« on: October 29, 2008 - 07:51:01 PM »
I just got the rear plate put back on my 8 1/4'' Rear End. It took me a few days to get the right gasket. My manual says it takes 4.4 pints of oil. When I emptied it, I got a little over a quart out. When I filled it a few minutes ago, it only took a little over a quart, so that seems right ( I think??).
 I'm going to go for a little drive and check the level again, will some of that oil move toward the axles and change the level leaving room for more oil?
Re: How much oil in 8 1/4'' Rear End"
« Reply #1 on: October 30, 2008 - 03:21:21 AM »
4.4 pints is equal to 2.25 qts so not enough , fill until  it is just level with the fill hole , should hold 1 more qt
