Author Topic: headlight issue  (Read 1065 times)
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
headlight issue
« on: October 30, 2008 - 03:17:27 PM »
heys guys i went to advance the othe rnight and got 2 highs and 2 low  for my car and when putting them back together 1 high and 1 low go on correctly but the other two do not go on correctl.. they do not seem to fit into the buckets correctly...... the buckets are installed correct ..... has anyone else had this problem???
Offline BadJoey
Re: headlight issue
« Reply #1 on: October 30, 2008 - 06:42:24 PM »
I just got 4 from Advance a week or so ago . Fit fine ? Can you compare them to your old lights ?
Offline Supercuda
Re: headlight issue
« Reply #2 on: October 30, 2008 - 07:00:44 PM »
Are you sure that you put them all in the right spots? I'm not trying to be an ass, just asking the obvious questions. The next one is this: Are you sure that you were given the correct headlamps for all 4 positions? There seems to be a problem with retaining good employees in the big chain stores. Re-check the headlamps against each other, the boxes they came in, and make sure that you have them rightside-up, too (I've done it-doh!). I am only aware of 3 different headlamp designs being used on classic MOPARS: the 2-lamp systems used a big lamp with 3 locating lugs on the back, and 3 electrical terminals. The 4-lamp system used a dedicated high beam lamp, small with only 2 terminals on the back; and a dedicated high-low lamp with 3 terminals, also a small diameter round lamp. The high beams will fit on any of the plugs, but will only fit the high-beam (inner) buckets. The outer lamps will also fit any plug, but will leave one spade uncovered when put in the inner bucket. I think that the outer lamp also only fits the outer bucket, but it's been a while since I have had to mess with a 4-round headlamp system. Neither lamp will fit the bucket upside-down.
Offline WVUFELLA
Re: headlight issue
« Reply #3 on: October 31, 2008 - 06:46:09 AM »
come to find out one of the prongs on the back of the headlight was soldered on about 60 degrees in the wrong direction.. got another headlight fits like a glove .... car is finally coming together....... before anyone else does it ill go ahead and do it  :useless: thanks guys
