auto/manual swap
Author Topic: auto/manual swap  (Read 3480 times)
sleepychallenger
Re: auto/manual swap
« Reply #15 on: November 22, 2008 - 10:40:13 AM »
from here we moved back to the top of the car and removed the seats, automatic shifter and brackets, and drivers side vent
sleepychallenger
« Reply #16 on: November 22, 2008 - 10:42:25 AM »
pics
sleepychallenger
« Reply #17 on: November 22, 2008 - 10:50:02 AM »
when checking for fitment of the new transmission hump we noticed that it had an extra lift where we suppoes the cudas have a bump in the floor that the challengers dont. we smashed it down.
Offline macsdaddy
« Reply #18 on: December 12, 2008 - 09:01:52 AM »
good stuff, have you made any further progress?
Offline Daves74chally
  • "Yea.... I need another new pair of tires"
« Reply #19 on: December 13, 2008 - 10:14:03 PM »
Yea im bookmarking this one! Lets see more is possable. Iv been looking for what it took to convert auto to manual.
1974 Dodge Challenger 414 stroker, 727 trans, 8 3/4 posi [OO/`````\OO]
Buffalo, NY
sleepychallenger
« Reply #20 on: December 15, 2008 - 06:30:27 AM »
ok guys, i have been tied up lately. i will try to finish this post this week.
« Last Edit: December 20, 2008 - 06:53:39 AM by sleepychallenger »
sleepychallenger
« Reply #21 on: December 20, 2008 - 06:52:12 AM »
ok folks, here are the holes cut in the floor.
sleepychallenger
« Reply #22 on: December 20, 2008 - 06:56:49 AM »
transmission mounted
sleepychallenger
« Reply #23 on: December 20, 2008 - 07:05:14 AM »
remove the brake pedal by undoing the nut on the pedal rod and sliding the rod out. then lift up on the silver part and the pedal should drop right out. also remove the drivers side vent and pull the padding behind it back. this will need to be done to drill two holes for the clutch pedal bracket.
« Last Edit: December 20, 2008 - 07:14:36 AM by sleepychallenger »
sleepychallenger
« Reply #24 on: December 20, 2008 - 07:15:50 AM »
when the holes are drilled, slide the bracket mount through the holes
sleepychallenger
« Reply #25 on: December 20, 2008 - 07:19:04 AM »
install the new clutch/brake pedal assembly and clutch pedal bracket (on left in picture. hook up the brake pedal and install the clips for it. next comes the fun part
« Last Edit: December 20, 2008 - 07:22:36 AM by sleepychallenger »
sleepychallenger
« Reply #26 on: December 20, 2008 - 07:52:03 AM »
to make the installation of the over center spring easier, put the short hook end in a vice and lock it down. take washers and install them in the spring as shown. make sure you leave enough room to get a screwdriver or pliers in them to remove the washers after the spring is in. i believe that we ended up using 8 or 9 washers.
***CAUTION***
That is one tough M F'n spring.
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #27 on: December 20, 2008 - 10:37:20 AM »
Looking good bro!
Don
Member Since January 14, 2002
Offline Sean
    • My Cuda Restore
« Reply #28 on: January 05, 2009 - 04:31:19 PM »
Can't wait to see the rest of the pics!!!  Great progress, Drew!!!
Sean
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« Reply #29 on: January 05, 2009 - 04:39:50 PM »
Nice :2thumbs:
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
