Author Topic: Steering shaft  (Read 660 times)
Offline noschevys
Steering shaft
« on: October 31, 2008 - 08:27:48 PM »
With the steering column removed from the car, what is the best way to remove the remove the shaft so it can be refinished on a 71 chally?
Re: Steering shaft
« Reply #1 on: November 01, 2008 - 03:07:45 AM »
the inner shaft is retained at the top in the brg with a snap ring & the lock plate also has to be removed to slide the shaft out , so you have to disassemble most of the top of the column , might as well remove thal the parts & clean & paint all of it
