When I use the turn signals, my Pioneer CD/tuner will cut out temporarily for a second, come back on for a few, then cut out again. It does not seem to parallel the blinker flash. The CD/tuner works fine otherwise. It doesn't matter if the headlights are on or off. The power to the CD/tuner is through one of the orange auxillary ports on the wiring harness. The wiring and alternator are new. The amp meter runs at the center, neutral, position when driving and shows a deflection to the discharge side when the brakes, blinkers, lights, etc are on. Am I overloading an aux circuit or have a low voltage issue? Maybe the new alternator (stock replacement) is not working properly? Suggestions?
