Author Topic: Piston oiling  (Read 922 times)
Offline Shane
Piston oiling
« on: November 01, 2008 - 09:20:18 PM »
New rod bearings (Clevite 77) don't have notch in lower half for oil passage through rod to squirt oil on bottom of piston. Do I need them?
Mopar 5.9 Magnum block
Shane
Re: Piston oiling
« Reply #1 on: November 02, 2008 - 12:18:05 AM »
doesn`t hurt , you could probably grind a notch in the brgs
Offline moper
Re: Piston oiling
« Reply #2 on: November 02, 2008 - 06:10:58 PM »
No, you dont need them.
Re: Piston oiling
« Reply #3 on: November 03, 2008 - 01:10:33 AM »
it feeds oil to the cylinder walls , helps cool the piston & helps lube the cam ... still can`t hurt
Offline femtnmax
Re: Piston oiling
« Reply #4 on: November 07, 2008 - 11:28:58 PM »
I notice many of the rod bearings now don't come with the notches.   Also, many of the new engines are NOT set up to oil the cylinder walls, and engine life is longer (in general) than ever.  Maybe the extra oil was promoting a emissions problem.
All the oil that is fed to the rod bearings has to go somewhere, which must produce lots of oil spray off both sides of each connecting rod.  I'm guessing that spray must soak the cylinder walls with oil.
Phil
Re: Piston oiling
« Reply #5 on: November 08, 2008 - 04:17:38 AM »
still needs to oil the cam & cool the piston
Offline moper
Re: Piston oiling
« Reply #6 on: November 08, 2008 - 10:01:23 AM »
The change comes from wanting to control the oil windage, and cut down the oil the oil rings need to remove from the cylinder walls. It can hurt ring seal and cause emmissions issues in factory engines. So they stopped when piston and ring and wall finishe got better.
Offline Shane
Re: Piston oiling
« Reply #7 on: November 08, 2008 - 12:03:19 PM »
I ground small knoches to allow the oil squirt. Everything I could find about the subject of small block rods said it was critical to make sure rods were aligned properly to allow for piston cooling. Thanks for your input
Shane
