Author Topic: Power to Manual brake conversion  (Read 985 times)
Offline lemming303
  • San Antonio, TX
« on: November 02, 2008 - 11:43:28 AM »
I'm not buying anything yet. I'm just trying to get info. I did a search on Google and all I can find is stuff about mustangs and monte carlos.
What is involved in switching to manual brakes? Do I need to buy a complete kit or can I find master cylinder kits with pushrod and what-not?
Are the calipers any different on the brakes themselves? Can I use regular calipers?
The reason I want to run manual is so I can run a real aggressive cam and not have to worry about vaccuum. I already found the steering kit I want. If anyone knows a site I can go to get more info or a place that sells these types of thing I appreciate it. Thanks for the help.
Kevin
73 Challenger Rallye - first project
Re: Power to Manual brake conversion
« Reply #1 on: November 02, 2008 - 12:40:43 PM »
All you need is a disc/ drum master with the groove in the rear piston to retain the pushrod , I use 75 Dart with manual disc for this , the pushrod is availble from Mopar or find a used one , the calipers etc are std parts , not changes there , the other option is to run power fromt he power steering system using a Hydro boost
Offline GoodysGotaCuda
« Reply #2 on: November 02, 2008 - 12:47:48 PM »
I did the conversion recently
Master cylinder w/pushrod retaining groove
Pushrod (i bought one from a factory manual brake ebody)
Firewall reinforcement plate
The aluminum master I bought has too large of a piston however, it's quite a leg to brake the car. Something I'll have to tend to down the road.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline femtnmax
« Reply #3 on: November 09, 2008 - 09:14:52 PM »
Would a vacuum canister work for your engine combo???  Summit & Jegs sell them.   Unless its a race track only ride, on the street if you end up overshooting and plow into the back of something.  OHHH your gonna be bummed, as well as get the ticket.
Phil
