Author Topic: Gas tank vents on 73 cuda??  (Read 2423 times)
Offline lime73
« on: November 03, 2008 - 06:15:06 PM »
I hope someone can help me. I have looked at alot of books and microfiche schematics and cannot find any pics of the gas tank area. i need to knoew what the four vent tubes hook to , some type of canister?? what is this canister called and where can i locate one as mine was long since gone when i took possetion of the car. any help would be greatly appreciated. thanks
Re: Gas tank vents on 73 cuda??
« Reply #1 on: November 03, 2008 - 06:23:42 PM »
The cannister should be on the passenger's side of the engine. I guess it was called a charcoal cannister. If you don't have one, you can cap off those vent tubes...unless you want this to be totally correct.
Offline RUSTY Cuda
  • One big step foward!
« Reply #2 on: November 03, 2008 - 06:45:10 PM »
There's a seperating ??? canister ???  located just above the tank on the rear crossmember(front of tank) gonna see if I have any pics of it. four stubs for the tank hookup & another that goes to the vapor return line up front.
Offline lime73
« Reply #3 on: November 03, 2008 - 07:46:52 PM »
any idea what this vapor seperating canister does ?  any idea where i can locate one or can i just cap off 4 tubes on tank without fear of tank not being vented?
« Reply #4 on: November 03, 2008 - 07:52:27 PM »
The canister should be on the passenger inner fender at the radiator support, about the size of a 1-lb coffee can, has 3-4 vacuum hoses... I'll suppose yours is gone. You can plug up the vent tubes but you will need to change to a vented gas cap, or drill a small hole in the one you have to prevent a vacuum lock. OK ot leave open to the air but you may smell fumes in a closed garage.
« Reply #5 on: November 03, 2008 - 07:55:17 PM »
On a cuda/barracuda, the hole in the gas cap will leak since the fuel neck is behind the tag. You can get a different fuel sending unit and do a propper vent system
Offline DAWGS73
« Reply #6 on: November 04, 2008 - 09:25:14 PM »
I ran the main vent line out to a point near the engine well. Put a one way check valve in the line there, allowing for the intake of air only, so that I still have the needed venting into the fuel system. No gas smell, and by leaving the line higher than the fuel tank, there shouldn't be any chance of a syphoning problem. I do not have the cannister ant this has worked for me without problems..... Only thing that has to be considered is which way the check valve is put in the line. Has to allow for air to be drawn in toward the gas tank, not the other way around. No hole in the gas fill cap needed. No smell of gas in the garage 'cuz it doesn't allow for air to escape from the tank into the engine bay.
