Author Topic: mics hardware & gaskets needed.  (Read 513 times)
Offline RUSTY Cuda
  • One big step foward!
« on: November 03, 2008 - 06:58:09 PM »
I know you guys posted the link for the rally mirror gaskets before, of course now I can't find it, thats the first item I need .
On a 73 cuda the scoop inserts are held on by 2 speed nuts & 2 very odd philips head screws, that go into rubber grommets with a threaded piece in the back, I need 2 sets of each, 8 screws & 8 grommets.
Lastly I need the speed nuts for the smaller emblems, for some rason all the ones I removed & cleaned up are way big, won't grip the studs. they are 5/16th heads, could use at least a dozen.
Any help appreciated!
A quick question, put on my 'Cuda 360 emblems & only got a speed nut on the front stud, the rears one is under the inner frame, how the He.....LL do you get the rear ones on??????????????????  Thanks  Rich!
Re: mics hardware & gaskets needed.
« Reply #1 on: November 03, 2008 - 07:26:14 PM »
R/T's got you covered
http://www.rtspecialties.net/proddetail.asp?prod=3035005
For the Hood callouts you need barrel nuts....PM your address & I'll mail you some.
Offline RUSTY Cuda
« Reply #2 on: November 03, 2008 - 10:27:09 PM »
Thank you, info pm'd to you.
Any leads on those grommets & screws for the scoop inserts.
Going to order the mirror gaskets now, will see if they list that hardware for the scoop inserts while I'm there? Rich
Offline RUSTY Cuda
« Reply #3 on: November 03, 2008 - 11:14:38 PM »
Ok, they had the hardware for the scoop inserts, so they & the miror gaskets are ordered, maybe now I can finish up the hood! YEA! thanks again,Rich.
