Author Topic: Speedometer gear  (Read 4827 times)
Offline Husker Cuda
Speedometer gear
« on: November 03, 2008 - 08:38:08 PM »
Need your help!  My 'Cuda came factory with a 3 speed manual.  I changed it out for a A-833 4 speed and put the speedometer gear out of my 3 speed thinking my speedometer would be accurate since I kept the factory 3:23 gear gear.  Now that I know it obviously has a different ratio in the 4 speed, what gear do I need to make my speedometer accurate again?
thanks
1974 'Cuda 512 stroker 650HP Indy heads, Hemi 4 speed, pistol grip - restored to new.
1970 GTX 440/727 Y4 Gold w/ black interior
1969 Camaro SS 396 4-speed X22
1970 Chevelle SS 396 - 375HP M22 4 speed
Offline 6packCuda
Re: Speedometer gear
« Reply #1 on: November 03, 2008 - 09:46:31 PM »
Hey Husker, your inbox is full. :2thumbs:
Offline Husker Cuda
« Reply #2 on: November 03, 2008 - 10:01:11 PM »
Sorry!, got it cleaned out now. :bigsmile:
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #3 on: November 04, 2008 - 01:02:14 PM »
it measures tail shaft speed, you dont need a  different gear.
« Reply #4 on: November 04, 2008 - 01:37:26 PM »
it depends on tire size but 32/ 33 tooth should be right
« Reply #5 on: November 04, 2008 - 04:53:24 PM »
The charts showed I needed a 33, but the 34 did the trick.   :grinyes:
Offline Husker Cuda
« Reply #6 on: November 05, 2008 - 08:17:23 AM »
My tires are P275-60 15 which show 28".  Mymopar site shows that I need 2838931(Green) which is a 31 tooth but they are showing this for a 3:21 ratio.  I would think this would be close?
thanks
« Reply #7 on: November 05, 2008 - 08:39:46 AM »
thanks
That's the problem I had. That chart showed a 33 for my car, but it was using a 3:21 ratio. My rear is a 3:23, so I needed a 34 tooth instead. I have a hunch you will need a 32, but 31 will be close...about 6 MPH fast at 60 MPH.
Offline Husker Cuda
« Reply #8 on: November 05, 2008 - 08:53:58 AM »
I think your hunch would be closer, I'll try the 32 and let you know how it works out.
thanks!
Offline wally426ci
    • maryland mopars
« Reply #9 on: November 05, 2008 - 08:59:51 AM »
Anyone have a good chart to use? some use Tire size, some use Tire height....
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Changin Gears
« Reply #10 on: November 05, 2008 - 12:47:09 PM »
This is from my previous post:
All you have to do calculate the number of teeth required is measure how far off your current speedo is, convert to percent, then get a new gear with the same percentage different teeth.  Example:
Hold your speed at 60mph between 2 mile markers, it requires 54 seconds to travel the distance instead of 60 (you could also use a GPS to get your true speed).  Your speedo is reading 10% low (your really going 66mph).  In this case, if your current gear had 30 teeth you would need one with 27 teeth (10% less) to speed the speedo up.
This equation also works:
Number of Teeth = 259 * (axle ratio/tire diameter)
Offline wally426ci
    • maryland mopars
« Reply #11 on: November 05, 2008 - 01:01:25 PM »
After reading the last response, I:
1.  ???
2.  :faint:
3.  :clueless:
 :chatting:
 :bigsmile:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #12 on: November 05, 2008 - 04:18:53 PM »
Changin Gears must have majored in math.    :lol:   :lol2:
Offline Husker Cuda
« Reply #13 on: December 12, 2008 - 09:08:08 PM »
Ok, I have installed my new 32 (black) gear and went out with my GPS.  At 60 on the GPS I was running 45 on the speedometer!  15 MPH off, now what do you guys suggest.  Again I am running a 3:23 SG with P275 60 BFG's (28")
thanks,
« Reply #14 on: December 12, 2008 - 10:09:50 PM »
sounds like you are 30% low so add 11, so 43 tooth but that would be way off from my experience
 Duh went the wrong way 22 would be close , something else is wrong
« Last Edit: December 13, 2008 - 12:25:22 AM by Chryco Psycho »
