Author Topic: Speedometer gear  (Read 4824 times)
Offline vinb
Re: Speedometer gear
« Reply #15 on: December 12, 2008 - 10:27:15 PM »
Run a 31 tooth with the 3.23 gear & 275/60/15 tire
Run a 33 tooth with the 3.55 gear & 275/60/15 tire
I drove down the highway after 3 miles, the speedo was off about a 1/2 to 1 tenth..
RPM was about right....
Offline Changin Gears
« Reply #16 on: December 12, 2008 - 10:31:49 PM »
Ok, I have installed my new 32 (black) gear and went out with my GPS.  At 60 on the GPS I was running 45 on the speedometer!  15 MPH off, now what do you guys suggest.  Again I am running a 3:23 SG with P275 60 BFG's (28")
thanks,
Your 33% off, so you would need 10 or 11 fewer teeth on the speedo gear (smaller gear will spin faster, making the speedo read higher).  I don't belive there is a 21 or 22 tooth gear.  Sounds like you have speedometer problems.  Is the odometer off also?
Offline vinb
« Reply #17 on: December 12, 2008 - 10:44:37 PM »
Easy,  just have someone with a late model car (digital dash) ride along side you at a specified speed and see what you have.
But if you have a 31 tooth in there it has to be correct unless you have a speedo problem.
With the 4spd you have no slippage and the rpm's should be 2327 rpm @ 60 mph & 2714 rpm @70 mph...
Hope that helps......
« Reply #18 on: December 13, 2008 - 09:16:13 AM »
I have an Excel spreadsheet that calculates the speedo pinion tooth # based on variables you can change such as rear ratio & tire size...Anyone that want it PM your email address with request.
Offline vinb
« Reply #19 on: December 13, 2008 - 10:00:21 AM »
bullitt99, is this the one?
http://www.moparts.org/Tech/tech/img/4SPEEDchart.xls
Also, I saw another one that you could put in your data and it would have a working tach & speedo from a B-Body, can't remember where I seen that one before...
« Reply #20 on: December 13, 2008 - 12:07:01 PM »
Yes that's the one, last time I looked they had removed it. & this one for automatics
http://www.moparts.org/Tech/tech/img/AUTOMATICchart.xls
« Last Edit: December 13, 2008 - 12:10:19 PM by bullitt99 »
Offline Husker Cuda
« Reply #21 on: December 13, 2008 - 08:23:42 PM »
I plugged in my numbers and it shows a 31 (30.25) gear, I'm running a 32 but it surely wouldn't be off that far so I must have speedometer issues?  It seems like I have to be going 10 or 15 mph before it even comes up off of the pin, could the needle just need pulled off and reattached on the zero location?  It does seem pretty smooth once it gets above 15 or 20 mph.
1974 'Cuda 512 stroker 650HP Indy heads, Hemi 4 speed, pistol grip - restored to new.
1970 GTX 440/727 Y4 Gold w/ black interior
1969 Camaro SS 396 4-speed X22
1970 Chevelle SS 396 - 375HP M22 4 speed
« Reply #22 on: December 13, 2008 - 08:43:48 PM »
I have never tried that but it could work  :dunno:
« Reply #23 on: December 13, 2008 - 09:34:40 PM »
I'd think clean & lube the mechanism would be the next move.  :2cents:
Alaskan_TA
« Reply #24 on: December 13, 2008 - 09:58:01 PM »
I agree, make sure the speedo cable is clean, the jacket & the inner drive.
I have a used 31 tooth here you are welcome to it if you want to try it? If so, email me with your mailing address.
Offline Husker Cuda
« Reply #25 on: December 15, 2008 - 05:57:12 PM »
Thanks for the offer Alaskan, Let me do some work on the speedometer first and then I'll see how far I'm off.   :cheers:
« Reply #26 on: December 15, 2008 - 07:56:09 PM »
You are the first to try to calibrate your speedo with a GPS. I just wonder how accururate a satellite millions of miles away is?  I was reading 80MPH at 60, but I have NEVER seen someone reading SO slow the other way. The lowest speedo gear here is 26 teeth, so I question how you are doing this. Just get someone to drive a steady 60 MPH ahead of you, and see what you read.
