Author Topic: 318 Exhaust manifold to pipe connector  (Read 744 times)
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
« on: November 03, 2008 - 10:58:48 PM »
I bought a 2.5inch "Header-Back" exhasut kit (Challnger, 318) but, now I want to keep the stock manifolds. Can I get the connector from manifold to pipe from a local exhaust shop? What would you call it?
Re: 318 Exhaust manifold to pipe connector
« Reply #1 on: November 04, 2008 - 01:15:52 PM »
with TTi they make the same exhuast either way so it is just a matter of ordering the front pipes , making the front pips is gernerally not too hard but almost everyone uses the factory flanges which are thinner & can warp & leak , if you didn`t buy TTi using TTi pipes may not work for you & I am not sure if you have any flanges to use
Offline e-tek
    • E-Tek Resto's
« Reply #2 on: June 28, 2009 - 09:57:21 AM »
I ended up fabbing my own set from the stock mani to the 2" SUMMIT set-up I bought. Had a shop strecth a piece to the collars for me, then bent and wleded a few sections to get a decent fit.
Offline Katfish
  • 70 Challenger
« Reply #3 on: June 28, 2009 - 11:45:51 AM »
Got any pics of the results?  I have tock exhaust connected to previous header system.  Job the shop did connecting the 2 is not pretty.
