Author Topic: TC's Hemi Resto  (Read 15458 times)
Offline ntstlgl1970
  • T a c o c a t
Re: Prior rebuild that was done to my Hemi
« Reply #75 on: April 14, 2010 - 03:51:19 PM »
Hi Mike,
The heads look great, looks like they did a nice finish on the deck as well.
I noticed that the valve springs are dual with a damper, does the cam maker say anything about breaking in the cam with the inner spring removed? I only ask because I had a cam where they stated that was the proper procedure with the same type valve springs you have.
« Reply #76 on: April 14, 2010 - 04:27:48 PM »
Hi Mike,
Good question Eric.
I spoke with Bullet cams Tech and wrote down their recommendations. Then I gave that info and their phone no. to Angie at Mopar Engines West who did the heads.
Angie highly commended the repair work done earlier to the head. Said it was some of the best repair work she had seen in a long time.
Based on the cam I'm using, the lift is .565. Bullet said to keep spring pressure under 350 lbs for the break in period regardless if using single or dual spring. So far it doesn't look like I'll need to remove the inner spring because the cam valve spring requirements fall just under the 350 lbs.
Dave her Dad will be doing the Dyno on it once I get everything put together and bring it over. Rocker shafts are getting polished today. Intake is getting bead blasted too.
Offline ntstlgl1970
  • T a c o c a t
« Reply #77 on: April 15, 2010 - 03:26:36 PM »
cool, that will save time/cost on the dyno session.
« Reply #78 on: April 21, 2010 - 06:39:30 PM »
Heads are on. Just a few minor things left and it should be ready for paint.
The front portion is already painted. I did it that way so I could spray it on before the harmonic balancer went on.
Intake won't get total paint on it until after break in and re-torque.
« Last Edit: November 24, 2014 - 09:08:30 PM by Topcat »
Offline Oldschool
  • Member Since 9-05-06
« Reply #79 on: April 22, 2010 - 09:14:55 AM »
Lookin' great TC....    :2thumbs:
Ken  --  In Georgia
Offline BIGSHCLUNK
« Reply #80 on: April 22, 2010 - 09:19:22 AM »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #81 on: July 13, 2010 - 09:29:11 PM »
Primered it first with high temp primer in the hot areas.
Painted with Roger Gibson correct Hemi Orange. Used the whole pint up.
« Last Edit: November 24, 2014 - 09:14:45 PM by Topcat »
Offline BIGSHCLUNK
Re: TC's Hemi Resto
« Reply #82 on: July 13, 2010 - 11:10:06 PM »
 :2thumbs: BIGS like!!
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline dutch
Re: TC's Hemi Resto
« Reply #83 on: July 14, 2010 - 03:41:45 AM »
looks sweet....  :bigshades:
good idea to chain it to the shop too....  :2thumbs: :biggrin:
*** Bart ***
Offline MOPAR FANATIC
Re: TC's Hemi Resto
« Reply #84 on: July 14, 2010 - 05:35:54 PM »
[/quot
e]
Yes it is.buddy of mine years ago had his original 70aar 340 stolen from dunwoody institute.while going school there.me myself would have never left it alone inshop class over the weekend.  :nono:
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
