Author Topic: Need Help. Where do these parts go?  (Read 1579 times)
Offline G_Man440
« on: November 05, 2008 - 02:07:33 AM »
I am stumped.  :clueless: Does anyone know where these parts go?
 :1zhelp:
70 Challenger R/T, 440, 727, AC
Offline asm74
Re: Need Help. Where do these parts go?
« Reply #1 on: November 05, 2008 - 02:13:47 AM »
Pic one are plastic insulator shields for the doors  They go below the latch mechanism, under the interior door panels.
Pic two looks like the stock ground strap that connects from the engine block to the firewall.
73 Challenger
« Reply #2 on: November 05, 2008 - 02:17:37 AM »
I agree , I have a pic of the plastic parts on my car if I can resize it down
Offline G_Man440
« Reply #3 on: November 06, 2008 - 02:04:45 AM »
Thank you for the help so far. I should be able figure out the shields.
I had the ground wire bolted to the transmission housing while in storage so I figured it went there, but I do not know where it goes on the firewall. I have looked at multiple cars at the last Mopar show and none of them had the wire. Not sure why.
« Reply #4 on: November 06, 2008 - 12:09:38 PM »
the ground strap doesn`t seem original to me
Offline DAYLEY/CHALLENGER
« Reply #5 on: November 06, 2008 - 12:17:54 PM »
The ground strap on mine is bolted to the intake and then to the firewall.  Looks orig to me.... :dunno:
Dave or David
« Reply #6 on: November 06, 2008 - 12:44:21 PM »
no gorund strap on mine other than the battery cable
Offline ROMI
  • 71 Challenger R/T 340 4 speed, Lapeer Michigan
« Reply #7 on: November 06, 2008 - 01:15:45 PM »
 :iagree:  except it maybe looks a little long.
Offline drewcrane
« Reply #8 on: November 07, 2008 - 08:59:01 AM »
i found one of those ground straps on an imperial it was connected to the passengerside motor mount and then grounded to the k frame,im pretty sure of that location as it was on an origonal car,that is my take on that :stirpot: :2thumbs:
Offline coupman35
  • It going to be FUN
« Reply #9 on: November 08, 2008 - 07:38:28 PM »
 :canada:the ground strap look like a radio ground strap it look to clean to go under the hood .I seen some on radio before
1941 Dodge truck 340cu
1935 ford 3window coupe 327cu
1965 Acadian Beaumont Convertible 283cu
1973 Challenger 318cu
Offline bb71challenger
« Reply #10 on: November 08, 2008 - 07:46:45 PM »
My 75 Cordoba had a ground strap like that but I have never seen an E-body with one   :dunno:
*Brett*
Offline farmertan
« Reply #11 on: November 08, 2008 - 08:10:06 PM »
heres where mine is on my 73 cuda pretty sure original
73 340 4sp 2nd owner since 85    brett
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
« Reply #12 on: November 10, 2008 - 04:20:30 PM »
I'm with farmtan.....i can't believe how many people don't re-install ground straps and then wonder why the electrical is messed or the lights flicker!
Offline G_Man440
« Reply #13 on: November 11, 2008 - 01:35:41 AM »
Thank You asm74 and everyone else. The door shields are in.
I found some other pictures showing the ground wires as well as the one posted here. Thanks farmertan for your Cuda pic.
I think I may have mounted the ignition box into one of the holes that was for the ground wire. I remember only having to drill one hole and using an existing one in the firewall.
