Author Topic: Stuck at work and need flasher info before I go home.  (Read 1068 times)
Offline TRIPLE-GREEN
    • Coupe Custom Accessories
« on: November 06, 2008 - 06:47:31 PM »
I am converting over to led. I know that i need a no load flasher. but I wanted to ask will a flasher like this ...
Work on the challenger?
I would think so but I also wanted to ask if they where 2 or 3 prong or something else all together. I am at work and can get a set but don't have access to the car. THANKS!!   Last do I need to replace both or one?
« Last Edit: November 06, 2008 - 06:50:09 PM by TRIPPLE-GREEN »
Offline Supercuda
Re: Stuck at work and need flasher info before I go home.
« Reply #1 on: November 06, 2008 - 08:13:36 PM »
The flasher for your car should be a common, 2-prong unit. Don't forget the hazard flasher, too. Should be a 552, if my brain is properly inserted. Just ask for the one that is suitable for use with LED lighting.
« Reply #2 on: November 07, 2008 - 09:42:29 AM »
I didn't get this info until I got up from a long sleep. But where I am going with this is I took some time last night and installed the new LED's on the front parking lamps of my challenger. They worked great!!!!!! I didn't change the flasher. Is that going to be an issue or can I just not fix what an't broke?
Offline Supercuda
« Reply #3 on: November 09, 2008 - 05:59:15 PM »
If there's enough load to trip the flasher, leave it alone. You might be looking at the difference between LED at one end, and LED at both ends. There may be sufficient load now, but less when the rears go LED, causing them to not blink. If that happens, then buy the no-load flasher.
Offline ChallengerGary
    • Challenger Gary
« Reply #4 on: November 10, 2008 - 07:32:40 PM »
Learn something new everyday.
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
