Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Off Topic
Everything Else
(Moderators:
4Cruizn
ChallengerHK
Oldschool
Garage heaters
« previous
next »
Print
Pages: [
1
Author
Topic: Garage heaters (Read 1203 times)
CrazyPete
Full Member
Garage heaters
on:
November 06, 2008 - 07:02:05 PM »
Since winter's right at out doorsteps i decided to pick up a propane tube style heater are these things any good? I was pretty cheap but i havent used it yet its rated @30,000 to 50,000 btu's should be perfect for the shop im thinking(its a 30X36 garage) atleast until i get the heat and ac hooked up next spring what do ya think?
Logged
1970 Dodge Challenger T/A
http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak? No it's just sweat from all that HORSEPOWER"
sadil340
Sr. Member
Re: Garage heaters
Reply #1 on:
November 06, 2008 - 07:13:49 PM »
I used a 50k BTU kerosene jet heater for years before I built my garage with a Modine gas unit and it worked great. You can even buy a thermostat that you plug the heater into that regulates the heat automatically if you want to fire it up before work starts and go have a coffee.
Logged
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
farmertan
Full Member
Re: Garage heaters
Reply #2 on:
November 06, 2008 - 08:39:13 PM »
there ok but there noisy and sometimes smoke a little when fired up the ventless propane wall mount heaters work real good but your area might be to big for one of them.
Logged
73 340 4sp 2nd owner since 85 brett
moparmaniac59
Resident
Drive it like ya stole it!
Re: Garage heaters
Reply #3 on:
November 06, 2008 - 08:50:14 PM »
I have several friends that have the heaters that burn used oil. It will burn just about anything. Motor oil, vegetable oil ect. The initial cost may be high, but once installed you can virtually run it for free as long as you know folks that have used motor oil ect!! Too bad they haven't been approved for home useage yet. At least not here in Virginia.
Matt B.
Logged
Matt
Moparal
Permanent Resident
Re: Garage heaters
Reply #4 on:
November 06, 2008 - 10:13:11 PM »
I got a 3 brick propane heater in my shop 40x30
This heater I use came out of my other house. It is made for indoors, wall hanging and doesnt require a vent. It is made to run vent free. I have enough little air holes around my shop that if vents were required for my unit, it could still get some air. I won't run it if painting is going on.
Last Edit: November 07, 2008 - 04:28:16 PM by Moparal
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Garage heaters
Reply #5 on:
November 07, 2008 - 02:27:21 AM »
don`t let it run too long , propane gives off CO too
Logged
ksierens
Sr. Member
Re: Garage heaters
Reply #6 on:
November 07, 2008 - 08:50:58 AM »
I have used them in the past also, be carefull if you are going to paint anything, first there is an open flame, and second, I have gotten some bad results because I think there was some airborne oil that contaminated the parts I painted.
Logged
1970 Triple Black Challenger R/T 440 Six Pack - 4 Speed - 3.55 Dana
Kurt - SE Michigan
twist
Jr. Member
Re: Garage heaters
Reply #7 on:
November 07, 2008 - 09:35:11 AM »
I used one of those, it was inexpensive and put out a decent amount of heat. Problem was the CO level would really go up in the garage and I would get a bad headache if I worked in there too long. I ended up putting in a Mr Heater ceiling mount unit unit from Northern Tool. Now thats the way to go - really fast heat up, without the funes.
Logged
68 Charger RT
68 Dart GT Convertible
matt63
Sr. Member
Re: Garage heaters
Reply #8 on:
November 07, 2008 - 10:05:30 AM »
I've been using a Reddy 50,000 btu propane heater the last month or so and it works well. It will heat a double garage up pretty quickly. You won't want to leave it on continuously and I don't leave it unattended. I have had no problems with CO and there is no ventilation. I'm sure the CO level must have risen but not enough to cause problems when running it for 15 minutes or so.
Logged
Matt in Edmonton
'68 Valiant
CrazyPete
Full Member
Re: Garage heaters
Reply #9 on:
November 07, 2008 - 01:50:51 PM »
thats the feedback i was looking for thanks everyone this lil heater should work good enough for this winter
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Re: Garage heaters
Reply #10 on:
November 07, 2008 - 03:55:09 PM »
If You get worried about CO then pick up a battery powered CO detector for 20 bucks and toss it in the garage. Propane burns pretty clean and you could crack a door or window for some make-up air.
Tom
Logged
Tom
arcticmopar
Jr. Member
Yukon Canada
Re: Garage heaters
Reply #11 on:
November 07, 2008 - 04:16:09 PM »
I have a tube style propane heater in my shop (23x32).The tube runs full lenth of the shop and vents outside. It will use propane in a hurry if left on all winter but it can heat my shop up overnite enough to work on my sleds (even in -40to -50c)
Logged
RUNS WHITH SISSORS! and DIGITALY CHALLENGED!
CrazyPete
Full Member
Re: Garage heaters
Reply #12 on:
November 08, 2008 - 07:04:58 PM »
tried it out today seems to work pretty dam good a warm shop is a good thing
Logged
422STROKER
Sr. Resident
Member Since 6/3/06
Re: Garage heaters
Reply #13 on:
November 08, 2008 - 07:55:44 PM »
Sweet, We are having a warm spell here lately(low 60's). Hopefully won't need too much heat this year.
Tom
Logged
Tom
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Off Topic
Everything Else
(Moderators:
4Cruizn
ChallengerHK
Oldschool
Garage heaters
