Author Topic: 8.75 Brake Question  (Read 564 times)
Offline RusTy/SE
  • Just havin' fun
8.75 Brake Question
« on: November 07, 2008 - 12:25:26 AM »
Is the diff between 10 1/2" and 11" rear drum brakes solely in the brake hardware? In other words on my original 10 1/2" drum rear end, if I decided to change to 11" would the brake hardware be the only parts changed or would the lines and or axles be different as well?
Russ :clueless:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Re: 8.75 Brake Question
« Reply #1 on: November 07, 2008 - 01:05:58 AM »
the switch is easy , you need all the parts , the backing plates drums etc all have to be 11"
« Reply #2 on: November 07, 2008 - 06:38:30 AM »
I got all the stuff here if you need it Russ :2thumbs:
