Author Topic: Sleepychallenger  (Read 810 times)
nivvy
Sleepychallenger
« on: November 07, 2008 - 05:20:42 AM »
hey drew. found some good stuff for you......  :2thumbs:
combo:
383 block (now 449ci)
440 crank 3.9 stroke
6.7" 'chevy' rods 2.2" pin
windage tray
diamond flattops
OOTB 84cc eddy's 10,5:1 CR
holley SD intake
OOTB 850 mighty demon
hydraulic XE284 compcam 240/246@.050 .507/.510 lift
1.6 ratio adjustable rockers (.541/.544 lift now)
MP dist with FBO coil&ECU
carter HV mechanical feul pump
727tf tranny with TF-2 kit and 10" TCS custommade converter with arround 3300rpm stall
runs on pumpgas
Numbers: 393hp and 605nm ( 446 ft/lbs) torque at the wheels, about 550HP at the crank.....
nivvy
Re: Sleepychallenger
« Reply #1 on: November 09, 2008 - 12:03:18 PM »
just in case drew missed it...... TTT
