Author Topic: 29 years late .... r  (Read 104365 times)
Offline Tubbed440
  • Suspension NinJa
Re: 29 years late .... r
« Reply #420 on: January 27, 2010 - 11:51:15 AM »
 :smilielol: :smilielol: :smilielol:  I love the method of engine install.  That is awesome!  Was budwieser involved?  (jk)
Nice looking project, and it looks to be coming along quite well.   :thumbsup:
74 Dodge Challenger
500 inch stroker, Full cage, ladder bars,
coil-overs, 4L80E, 325/50 M/T DR's....street car!
(work in progress)
Offline bb71challenger
« Reply #421 on: January 27, 2010 - 06:13:19 PM »
Hey Neil, I  have a question about your exhaust manifolds. I had a couple of sets of the magnum manifolds. I still have one set left and I was wondering if you have done anything exotic to yours like extrude honing or porting? I did a little bit with a set like taking out the heat riser flap and doing a bit of porting but nothing much at all. I would love to run them as they are much quieter and look better imo. How much hp are you giving up by using them? Great pics btw, seeing you holding up the car somehow makes that form of install seem easier.   :2thumbs:
*Brett*
Offline Cuda Cody
  • Vancouver, WA
« Reply #422 on: January 27, 2010 - 06:28:02 PM »
Love it!  :woo:
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #423 on: January 27, 2010 - 08:55:23 PM »
CP what is up with running the fuel lines on the throttle side? i have never seen that, Is there a benefit ?
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline the_engineers
« Reply #424 on: January 27, 2010 - 10:05:42 PM »
He's not using center-hung float bowls...not sure "why"
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #425 on: January 27, 2010 - 10:57:19 PM »
They look to be GM holley dueces. I read a story about Mr. Norms using them because they were cheaper by a bit. Other than the fuel inlet swap they are the same as far as I know.   :dunno:
*Brett*
« Reply #426 on: January 27, 2010 - 11:30:54 PM »
The carbs are 69 RR mechanical carbs , date coded too , these all have the accellerater pumps on them , & they all have metering blocks so you can tune the jetting , if you add the metering blocks & the race bowls there is not enough space between the carbs so you have to use the side hung float bowls . As I said these are as delivered 69 RR carbs Not GM application & trust me these carbs were not cheap to get , but when you stand on the loud pedal all 3 carbs are instantly Wide open , no waiting for vacuum to get the outbaord carbs involved !! I figured these would be the killer setup on top of 512 " of solid cammed big block & allow all the tuning advantages .
The exhaust manifolds are no longer stock , anyone who knows me knows I cannot sacrifice power , I did not get them extrude honed although I probably should have , you have to draw the line financially somewhere , but there are extensively ported everywhere I could reach & the heat riser flap oddly fell out after grinding on it LOL
I would love to take credit for being a strong MOFO & I am not weak     But the reality is if you place the stands under the front spring hangers it is only maybe 150# lift to raise the nose of the car , you just need a friend to raise the stands while you lift , I was able to hold it long enough quite easily to have my friend remove both stands , take the picture & replace the stands set much higher so the engine would roll under the frame rail
Offline Street_Challenged73
« Reply #427 on: January 27, 2010 - 11:51:42 PM »
Very nice progress, Neil!!! :cheers:  That's going to be awesome once you have it all finished up. :2thumbs:  I still remember how wicked your old 'Cuda was and miss seeing an avatar or signature photo of it, but I think this Chally should fill that void (at least for my eye candy needs). :lol2:  Oh, and I love how someone else seems to think it's not too bad to pick up the front end of these cars while the engine is out. :thumbsup:  I did that for mine when I needed to pull it off the stands it had been resting on for close to five years! :faint:
Offline 74chall
  • Mopar or No Car
« Reply #428 on: January 28, 2010 - 07:43:51 AM »
Nice!!!!!!!!  :2thumbs:
Are the heater hose nipples on your water pump housing the same size?
My heater core has two different size inlet/outlet and my water pump nipples are both the same size (440source nippels and alum pump housing) Im trying to figure out how to make the hoses work or what is wrong.
Offline ShelbyDogg
« Reply #429 on: January 28, 2010 - 09:46:10 AM »
Seems like you can just find the "sweet spot" for the stands, then just load up weight in the trunk, then the front should just raise up on it's own.
« Reply #430 on: January 28, 2010 - 11:33:27 AM »
My heater core is like yours with 2 different sizes , 1/2" & 5/8" , I had to install a bushing to use my 1/2" nipple in my water pump housing
« Reply #431 on: January 31, 2010 - 07:28:37 PM »
Thanks Jason  :2thumbs:
« Reply #432 on: February 05, 2010 - 12:18:48 AM »
TTi exhaust went on today , attached some trim , i have to polish up th front valance trim , started to polish it , cut the hole in the carpet for the shifter , deatiled the fan * clutch & installed them , realized I had not cleaned the shroud so I started working on that
Offline Jimmy
  • THE Challenge(r)
« Reply #433 on: February 05, 2010 - 07:55:10 AM »
Any new pics? I can't wait until I get to the stage you are at! Many years to come, but I'll get there.
1973 Challenger w/440
1967 Camaro RS w/502
1967 Mustang w/302
1965 Ford F100 w/429
« Reply #434 on: February 05, 2010 - 12:08:28 PM »
pix are coming  :2thumbs:
